Question about UltraBac Software Remote/Local Server Agent for PC
Remote starter problem...
I have Ultra remote starter... Truck starts up, runs for 5-10seconds, shuts down... not a gas problem... I think the remote has to be reset some how!!1
Hello i have a issue with my 95 GMC pickup its a duel fuel unit and the way my ultra start was installed it energizes the system and on the propane side dumps too much propane in before the engine cranks and floods with fuel and wont start do you have any idea on how i can solve this problem?
Posted on Oct 17, 2009
Either tach is not learned or tach wire is hooked up wrong
Posted on Oct 07, 2009
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
I have a 98 gmc Jimmy my remote lock battery died so we were unlocking the truck with the key and driving well that lasted only 2 days and the truck died we got a jump to get it home got a new battery...
Getting spark? Power coming from the battery I think you meant to say, if I am correct. If it won't jump start, sounds like a cable from battery to vehicle is not connected. Igniton switch connection or fuse maybe. Check the daisy chaining of the negative battery cable for clean contacts. Also a starter relay could be bad. Just some more suggestions to add. Don't drive to far from home until repaired. Towing cost too much as you know by now.
Never did like remote locks, We as humans seem to be getting more and more depended on convienances that cause us more inconvienances. Could try a positive cable to starter to check if it will turn over the starter. Voltage regulator could cause battery not to charge while driving. When car dies, do lights work or they dim from engine sucking battery dry. Just some suggestions.
Apr 05, 2013 | Cars & Trucks
My remote start was working fine and now it starts the 2003 chevy silverado but the truck shuts right back down.
Does the truck start and run when you start it with the key? If it does then you have lost continuity from the remote starter module. Check the wiring that has been added to your ign. switch it may be just a loose connection.
Mar 11, 2013 | Cars & Trucks
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
97 Chevy Truck starts and idles rough and then shuts down
Sounds like you're loading up with fuel. I'd check the fuel pressure regulator. Some engines are set up with a regulator inside the intake plenum, which requires plenum removal.
Oct 01, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Security light blinks on dash , truck wont even try to start
Does your key have a chip on it? If it does its probably the problem
Aug 23, 2009 | 2004 Dodge Ram 1500
Parking light malfunction
The remote starter is the culprit. Your vehicle has a body computer, and it is not programmed to understand the installation of a remote starter. More often than not, the remote starters cause very bizarre things to happen to the body computer. Best advice: Remove the remote starter before it causes permanent damage to the body computer. A BC replacment is over $1,200 dollars.
Feb 05, 2009 | 2006 Toyota 4Runner
Viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Jan 15, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Computers & Internet Logo
1,003 people viewed this question
Top UltraBac Software Computers & Internet Experts
David Payne
David Payne
Are you an UltraBac Software Computer and Internet Expert? Answer questions, earn points and help others
