Question about Refrigerators
Water leakage I have water leaking out the bottom all over the floor & into the bottom of the freezer of my 2 year old Frigidaire side by side. model # FRS6HR4HW2
    Problem Solver:
  • 9 Answers
DO YOU HAVE ICE MAKER?
Posted on May 26, 2009
Water leaking onto floor coming from under refrigerator
Their are a couple things causing that leak
1) the water valve(s) for the icemaker/door dispenser are leaking. Pull the refrif. out,remove service panel from the rear and inspect the valve(s) for leakage. Sometimes their is just one valve on certain models their is two.
2) the drain for the auto. defrost cycle in the bottom of the freezer back wall is blocked so the defrost water is running out of the freezer door at the bottom
Good luck,i hope i have able to help you stop the leak,
Aug 20, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
We have water leaking slowly from beneath the water/ice dispenser unit in our Amana side by side. It is 2 1/2 years old and this is a new problem.
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Amana ARS9266BS Side by Side Refrigerator
The bottom of the freezer is filled with frozen water. Also, there is an occasional water leakage found on the floor at the front side below the freezer door. Do you have any advise on how can I find the...
This can be the drain of the auto defrosted water that is overflowing from the collection tank. This is normally located at the bottom of the fridge and a little above the compressor in some cases.
So you will need to move the fridge forward to check on the bottom side of the back of the fridge.
The water can be drained out of the tank and reset.
Jun 16, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Water Leaking - Freezer
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
Apr 18, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
