I can't get my usual wireless internet connection anymore on my l
The wireless router is still working, I check with another laptop, I used the windows network diagnostics on the problem laptop It said a cable is not plugged into the network adapter, also that a am not connected to any networks. I have a desktop and It still has an internet connection using the same router. After years of internet use with this laptop all of sudden this happens. the laptop is a Mirus.
    Scholar:
  • 145 Answers
Make sure you don't have your wireless turned off on your laptop. Sometimes there is a button on the laptop.
or. Go to Control panel on laptop -- then system --then device manager and check to see if there are any "explanation points" on any of your devices listed. If so, right click on the one with the "exp point" and hit update driver. Then follow the process on the screen. Sometimes you may have to select roll back driver to get it working again.
or
The wireless adapter was disabled in the same device manager. if so, right click on the adapter line and check to make sure it is enabled.
Hopefully my explanation isn't too confusing. I appologize, I'm relative new at typing directions.
Hope this helps.
Posted on May 26, 2009
I can wire connect but to the internet through the router, but the wireless connection is not working anymore
Is your wireless adapter enabled on the device you are trying to connect to ( is it a laptop)? Do you see your wireless SSID when you search for Available Wireless Networks? shut down the laptop and start up the laptop. reaquire the signal.
Nov 07, 2012 | Linksys WRT310N Wireless Router
No internet connection?
The best way is to get a data cable and connect directly to the laptop. Your laptop should recognize the router and prompt you to make this your wireless device. Once through the setup you can unplug the cable and you should be set for wireless again. The one other thing to check is make sure the wireless button on the computer is on. Mine is on the front but I have seen them all over. Check the latter first.
Aug 31, 2012 | D-Link AirPlus DI-524 Wireless Router
Thinkpad Lenovo - suddenly no internet
How do you connect to the internet? Are you going through a wireless router or using a usb device provided by a cellphone provider?
Maybe you need to check your settings on the broadband service since you mentioned it. You could also reinstalled the broadband application if it is not solved.
May 14, 2012 | Computers & Internet
Router working but as soon has i secure it with a WEP key my wireless wont work anymore ???
You may need to edit the settings in the connecting computer, it may be using old specs and being rejected....without prompt, on some OS.
Jul 12, 2011 | Linksys Wireless-G WRT54GS Router...
I bought this US Robotics wireless (model 5461 (Maxg)) maybe 3 years ago. I haven't used it in maybe 2 years and now it wouldn't work anymore. I recently switched apartments and computer, it used to work...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Oct 04, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
The wlan doesn't work-it used to until last week! The flashing amber light on the front is completely gone and does not flash anymore! and it says that NO wireless networks detected - although my friend's...
1. check with you ISP. You may have an issue with the server.
2. check the connection in the router (router status) using 192.168.0.1 then enter "admin" and a password if used.
3.
1.Log into router
Aug 10, 2010 | Acer Aspire 3000 Notebook
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
I was able to connect my router to my wireless laptop successfully. Then I applied security settings to it using my laptop. And down went my internet. The router is working perfectly, but my laptop wont...
what you need to do is go to your wireless settings on you computer and remove the wireless network that you connected to before.
then go and reconnect to your network any wireless security settings that need to be entered should be asked for if not then you will have to reset router and the best way tto do that is to locate small reset hole on rear of router and push and hold for 10 seconds, router must be powered on
May 02, 2009 | Belkin (F5D7231-4) Wireless Router
Linksys Power cut problem
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Jan 19, 2009 | Linksys Wireless-G WRT54G Router
Laptop will not connect to the internet anymore.
are you using wifi connection, I mean wireless connection or you're hooking up to a LAN network or through a modem connection?  If all this connection wouldn't worked out anymore, try reinstalling your Operating System!
Dec 13, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
