Same Here !! Any suggestions?
Could be a convergence issue...have a look here:
http://forum.eserviceinfo.com/viewtopic.php?t=23895&start=20&postdays=0&postorder=asc&highlight=
Unplug the tv. then Try unplugging the connector CNZ03 from the convergence board. It is the red one on the left with the two blue/green wires. Plug the tv in and mine powered on imediately but you may have to push the power button. The led on the front was still doing it's flashing thing but the tv powered up, and made its happy little chime sound. The screen looked like a typical bad convergance issue, and rightfully so because the power has been removed from the convergance board. If you get similar results then most likely you need to do a convergance board rebuild. mine has a couple of burnt resistors and I am assuming that the STK392-040 IC's are bad too. If your set does not turn on and power up then you should search for other issues.
This may save you the added expense of replacing parts that are not bad.
I will try to re post once I have rebuilt my convergence board to let you know how it worked out and if the blinking light goes away.
will not turn on, power led flashes numerous times and then nothing
i have same problem with my unit blinking light ang red
I turn it on but there is no picture and the red light blinks.
i got the same problem what can i do?
same problem
On power up the red indicator light flashes but does not turn on the t.v. Is there a do it your self solution???
same problem
