Question about Plumbing
Lack of pressure
Grundfos Mod# A96523620-P20829227 wash pump I have lack of pressure and the pump is not 6 months old
  • George Fleming May 11, 2010
    did you ever run the pump dry?
    Sergeant:
  • 293 Answers
The pump is not properly primed due to suction leaks. Check for leaks in your suction line. Check also the integrity of your suction check valve.
Posted on Jun 11, 2009
Hard to start fuel pump has been checked
Need much more information about the car, age, care it has had. Only 4 things cause hard start. Lack of Air coming into the intake, Lack of Fuel, Lack of spark, Lack of torque from the starter. Assuming the starter is good & battery, and fuel is there, i would check the spark plugs, and spark output. If it has a lot of miles check the Air Filter. The injectors could also be clogged. I always dump 2 bottles of injector cleaner in the tank every 2 months. If you have never done this i would go for 3 bottles. Again the spark cannot be weak, fuel pressure cannot be low, or have restrictions like dirty a fuel filter, or dirty fuel injectors or even bad Gas. And last a computer problem providing incorrect timing to the Injectors or Spark Plugs.
Apr 23, 2016 | Nissan Pathfinder Cars & Trucks
High oil pressure
NOT LACK OF OIL AT ALL! FACTORY OIL PUMP OF AFTERMARKET HIGH VOLUME OIL PUMP? HOPEFULLY YOU INSTALLED DEFI GAUDE SENSOR IN PLACE OF OLD OIL PRESSURE SENSOR! ALSO OIL WEIGHT CAN AFFECT THIS ISSUE! AND LASTLY PRESSURE RELIEF VALVE MAY BE MALFUNCTIONING IN THE PUMP ITSELF
Feb 18, 2014 | Subaru Impreza Cars & Trucks
Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Nov 04, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Oct 30, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have had a Grundfos CME Booster pump installed for some ten months or so. We have a pump room alongside the 150,000 water tank. The inlet is suspended from a float within the water tank, and is about...
Hi Ray, did you ever solve your problem, I have a setup that sounds identical to yours and have the same problem, Grundfos are not been very helpful.
Oct 31, 2011 | Plumbing
My 39 month old pump stopped working today. Can
Any dealer can repair it. These pumps have a long life.
Dec 03, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Grundfos mq3-45 b has stopped working has and has alarm light on. looking for solution please
There are several reasons for the pump to go into alarm mode: 1. Overheating 2. Lack of water 3. leak on the suction side causing cavitation 4. Bad circuit board
This pump will try to re-start for 24 hours and will go into Standby mode if there is no water.
What happens if you push Start?
Sep 02, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Lack of Fuel
Just because the fuel pump is on does not mean it is delivering the proper pressure. Some systems need as much as 35 psi to function properly. I would look there. I am assuming that you have checked the pressure as you had mentioned that the "Injectors have a lack of pressure" in your statement. Some of the old chevys used to use a "Sock" type filter on the pick up tube in the fuel tank. A possibility? Could be partially clogged. Good Luck
Feb 16, 2009 | 1990 Chevrolet Camaro
Plumbing Logo
150 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
