Question about HP Televison & Video
No sound on hdtv when hook up to hdmi
When i hook up my laptop to my hdtv i get a good picture but no sound. i am useing a hp pavilion dv9030us notebook. and my hdtv is a 2005 dell 50 inch plasma. thanks rob
  • ROBERT MCVAE May 27, 2009
    i think this solution is for xp, i am running vista on my laptop is there a sound device procedure for vista? thanks rob
  • 77 Answers
Hi buddy u have to change ur sound setting from the Control panel.
ie by default the Sound is played through ur default sound card.but if ur using ur HDMI connection then u have to chage it frm control panel
Steps:Control panel>Sound N Audio Device>Click on the Audio TAB(the Third on frm the top_)>there u will find an option Sound played back and u will have Drop down option once u have connected the HDMI.afer u have selected the option click on apply>ok.then U will definatly get Sound frm ur TV.
Posted on May 26, 2009
    Problem Solver:
  • 7 Answers
Try this. hook up the cable, right click on your speaker icon at bottom right of screen, select audio devices, select the digital audio option, then restart your machine. Then you should be good. May have to do the opposite to get computer speakers working once you are done with the TV hook up.
Posted on Aug 04, 2009
My hp pavilion laptop dv9030us doesn't boot up
Try to check the SAFE MODE by pressing F8 on windows startup. Even in the SAFE MODE, if you are unable to boot windows properly, try to install/ Repair the operating system.
Jun 17, 2011 | HP Pavilion dv9030us Notebook
Can't get picture on HD TV using HDMI cable
The simplest method
1. turn off tv and laptop
2. hook up hdmi cable from laptop and then to hdtv
3. turn on laptop and once the laptop has booted fully,
4. turn on tv and select the source....
Feb 11, 2011 | HP Pavilion dv5tse Notebook
My hp pavilion dv9030us is having display problem i cant run window in normal modei have to run it in safe mode and when i do i have green blocks running in a straight line down my screen all over it.
All of this is caused by the video card, it has failed and must be replaced. Unfortunately this is a custom card, the only ones that have it are the repair shops from the HP dealers - you will have to take your laptop to one of them.
Dec 02, 2010 | HP Pavilion dv9030us Notebook
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
HP DV9030US Notebook w/XP Media Center SP3 (NO HDMI AUDIO)
there may be a connection on the board hardware wise that you need to connect, for the nvida control panel too see the hdmi
Jun 22, 2009 | HP Pavilion dv9000z Notebook
NO SOUND WHEN USING HDMI FROM PC TO HDTV (RUNNING VISTA)
When using an HDMI to DVI cable their is no audio that comes through that cable. Even if you use HDMI to HDMI most computers only have video output from HDMI. You will have to use a seperate audio cable for you to be able to get the sound to work. Depending on the output you have on your laptop you may have to resort to hooking up a pair of speakers to the headphone jack.
Hope this helps.
May 27, 2009 | HP Pavilion dv9030us Notebook
I have an hp laptop and a bravia lcd,both have HDMI .
use fn+ f4 to toggle display between notebook and hdmi tv ;.....but make sure the cable is connected properly at both ends.
Mar 17, 2009 | HP Pavilion dv6000z Notebook
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
Picture but no sound through my s-video hook up.
S video is just video, you need to run two rca jacks to the left and right audio channel thet the s video is on. The only one that runs both audio and video is the HDMI, component is 5 wires, s is 3, as is the old shhool rca 2 audio 1 video, so if you want the best picture and sound use the HDMI, next step down is Component, 5 wires, 1red ,1blue, and one green, just for the video, then the right and left audio. Or an optical audio, but HDMI is what you want, one wire does it all
Jan 03, 2009 | HP Pavilion dv6000z Notebook
Televison & Video Logo
696 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
