Question about Akai LCT2662 Television
Power Supply problems
14 capacitors blew up in the power supply, How do I get a new power supply
    Problem Solver:
  • 26 Answers
I can repair your power supply. Email me at tracy_tangen@hotmail.com.
Posted on Oct 18, 2009
    Champion:
  • 367 Answers
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Posted on Oct 07, 2009
I replaced my power supply on my Tv. The new part I got blew out on me.
Did you replaced the power supply as card basis; or, repaired it by replacing any capacitors at it. If you have replaced the capacitors only, the polarity of the capacitor you've replaced might be reversed. Capacitors have both +Ve and --Ve polarities, and should match with the markings at the board; otherwise it will burst when you power it up.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 22, 2014 | Vizio VF551XVT 55 in. HDTV
Why wont my tv turn on
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Jun 06, 2012 | Sylvania LC320SS2 TV
Looking for schematics of ATX200-3516 ASTEC power supply. When i plug in a dc motor i have a peak of current firstly more than 6 Amps (6 amps is max rating at 12 Volts in such supply). So It shut the...
If your power supply is rated 6 AMPS and your motor is rated 14 amps peek, then when that motor starts it will draw the 14 AMPS, That will trip the power supply right then and there. After it runs a few seconds the AMPS will drop about ½ that, but still 7 AMPS is more then the power supply is rated, so you will need a different power supply.
Aug 08, 2011 | Astec (ATX200-3516) (ATX2003516) Power...
My philips 14 inch tv is not working the capacitor 400v was explode and i change it i clean all the chemicals that were on the borde abd the fuse is new what can i do?
I would blanket change the power supply if it isn't working. The electrolyte is conductive and will do an awful lot of damage.
By your description "400v" I presume you mean the main smoothing capacitor, in which case the power supply has been drawing excessive current to make the capacitor leak so I would look next at the line output section.
Hope that helps.
Mar 03, 2011 | Philips 14PT1356 14" TV
Having problems taking a long time to come on if at all.
This problems alway the power supply board have dying parts call capacitors.Capacitors parts on it alway bulges up on it tops or puffing on it tops.The power supply board is the board that take in the power a/c cord and the causes,why power take along time to power up ur tv.U have tools and know basic electronic?Check all over the power supply board and changes those dying capacitors are bulging ups and puffing ups on it tops.Or tries website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 01, 2011 | LG 60PC1D 60 in. Plasma Television
My 50 in plasma has seven red lights flashing please help
If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Oct 24, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My pwoer supply blew up as well part number HGP 180-p240JIFE
Ladies and Gentlemen,
Relative to Olevia TV Power Supply Problems Solution provided by: kb8tez Matt, the problem he had was Electrolytic Capacitor CS21. Upon careful examination of the Power Supply Circuit Board I find that CS21 is in parallel with CS22. Simply replacing BOTH Capacitors makes for a more permanent fix. Radio Shack P/N 272-1032 1000UF 35V Capacitors @ $1.59 each plus tax makes a very inexpensive repair. Apparently the same power supply circuit board is common to many different Olevia Models.
Fastest Robe
Aug 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Power supply failed
HI....
It's not worth going after...Cyberhome doesnt give out tech documents.
Mar 25, 2009 | Cyberhome CH-DVR1500 DVD Recorder
Soldered in new fuse, blew it right away...whats a good upgrade?
A new power supply will fix your problem, and when the fuse blows do not replace it. It blows to protect your computer. please replace with a new power supply.
Oct 28, 2007 | Okia / 450-Watt / ATX / 80mm Fan /...
TV power supply problem
.01 mf 2000 volt. in flyback circuit .it is a timing capacitor. the red high voltage block is bad and that took out the capacitor. also check the horizontal output transistor...it is probably shorted.
Aug 25, 2006 | Sony KV-27V26 27" TV
Akai LCT2662 Television Logo
156 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
