Question about Gateway CX2618 Notebook
Gateway model # CX 2618
I recently took my laptop on a business trip when I returned I pluged in the laptop and now the screen is dark and blank. is there a trouble shooting I can do before i pay to have gateway fix it.
    Problem Solver:
  • 5 Answers
First test if it works on an external monitor. If it does you will need to clear the CMOS. To clear it:
remove the battery, unplug the cord, and hold the ON button down for 30-60 seconds. Then turn it on. Thats how you clear it on most laptops.
If it does not work on the external monitor, you probally have a bad video card and need to replace the old one
Posted on May 26, 2009
  • 916 Answers
Shine a flashlight on the screen and see if you can see a faint image. If you can it is a back light. If you can not it could be a few other things.
  • machadojr_fe May 26, 2009
How can remove the battery from gateway cx 2618
  1. Close the LCD panel.
  2. If your notebook is on and connected to AC power, or has a charged multi-bay battery installed, go to Step 4. If your notebook is on, is not plugged into an AC outlet, or does not have a charged multi-bay battery installed, save your work, and then shut down Windows® and turn off the computer.
  3. Turn your notebook over so that the bottom is facing up.
  4. If the notebook is equipped with a battery lock, slide it to the unlocked position.
  5. Slide the battery release latch, and then slide the battery out of the bay.
  6. Slide the new battery into the bay until it snaps into place.
  7. If the notebook is equipped with a battery lock, slide the battery lock to the locked position.
  8. Turn the notebook over.
  9. Reconnect the optional port replicator.
  10. Open the LCD panel and press the power button.
Mar 01, 2011 | Gateway CX2618 Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
In Youtube, when I click full screen, the screen turns blank.
you just right click and select a particular file for ex media player
so that u will able to view it
Mar 21, 2009 | Gateway MT6729 Notebook
Monitor screen ia blank
open it and see if you can find a blow capacitor on the logical lcd board...it´s very common to happen in this kind of model...
Good Luck!
Dec 04, 2008 | Gateway FPD2275W LCD Monitor
Monitor light
ok please check your laptop dc adapter.
and replace it if neede..
Oct 28, 2008 | Gateway MT3705 Notebook
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Dark screen but just replaced it
I have a compaq laptop Hp 5000 the screen was black and I took the batterie out for a few minutes pluged the unit in and shut it back down and put the batterie back in and now works
Jan 25, 2008 | Panasonic Toughbook 48 Notebook
Gateway CX2618 Notebook Logo
235 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
