Question about AT&T Blackberry Curve 8300 Smartphone
Clicker on my blackberry
Hello i have a blackberry there is not ball in the middle of the key board instead its off on the side.. anyways it appears to have gone off track i can roll it back and forth but not click it can anyone help
    Brigadier General:
  • 7,752 Answers
You may need a new phone if the trackball is on the side then the scroll is broken and maybe very hard to repair but you can try a repair shop and have them take a look at it.
Posted on Jan 31, 2010
Blackberry 9630 Trackball not working in the main menu
hold down alt key and swipe roll the ball. for emergency purpose. ferrah.com@gmail.com
Dec 10, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Cant get my ball to work
usually all blackberry phones with ball trackers experience this type of problem due to overuse
if you can fix it on your own,do it with care cause some parts are to sensitive.
* need a T6 screw driver
* open and unscrew all sides where the screws are located
* locate the track ball and dismantle it
* clean and align the board interface which the ball tracker is attach..
* assemble it with care....DONE
good luck....
Jun 09, 2011 | RIM BlackBerry Curve 8310 Smartphone
Half the screen is black and the other half is normal
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
PS The black screen on one side is also related to a bad control board ! John
Dec 09, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Keys Not Working after Water
there is an area under the track ball that goes bad if it get's wet. Cleaning that area with a brush can sometime get it up and running again. If you're out of warranty try to remove the trackball and clean the area below it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself.
May 28, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
I need to delete contacts and stored info from my 8700c blackberry- help!
Hi Mandeedougla,
Please do the following to wipe all your personal data and bring it back to default settings.
Press the Menu key "Placed Left of the ball".
In the menu, select 'Options' (Symbol is= Wrech)
Then Select 'Security Settings'
Then Select 'General Settings'
Now you will find many options here (ignore all)
Press the menu key again "Placed Left of the ball". A pop up will appear in the list.
Select the option, "Wipe Handheld".
It will warn you that all data will be lost. Select continue and press the ball key.
It will ask you to type the word "blackberry".
Type it and press the ball again.
It will wipe all the data off.
I hope that you will find this information useful.
Feel free to post a comment here if you still have any issues.
Thanks and Best Regards,
Techno-Geek.
Apr 27, 2009 | RIM BlackBerry 8700c Cellular Phone
Water damage to my curve, key board does not work, all else does
Hi
I'm looking for a new board for a blackberry curve 8320 since I had to blind the charger access so I'm wondering if you can provide me with the proper price of new board or secondhand
Jan 11, 2009 | AT&T Blackberry Curve 8300 Smartphone
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
When i am pressing my track ball its not responding
Get a sheet of paper or a pad of paper, put your cell upside down so the rollerball is touching the paper... Rub the phone on the paper quite vigerously. This has been a problem for me with many pearls - there is some dust / dirt lodged under the ball which stops it behaving the way it should. You may need to do this in all directions.
Mar 28, 2008 | RIM BlackBerry Pearl 8100
AT&T Blackberry Curve 8300 Smartphone Logo
173 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
