Question about Refrigerators
WILL NOT DEFROST. HAS NEW CONTROL PANEL. - Refrigerators
  • 3 more comments
  • billycrowson May 26, 2009
    I HAVE NO INTEREST IN HOW MECHANICAL DEFROST TIMERS WORK. WHAT I NEED TO KNOW IS WHAT KEEPS AN ELECTRONICALLY CONTROLLED DEFROSTER FROM WORKING WHEN THE MOTHER BOARD AND THE HEATER IS GOOD.
  • billycrowson May 27, 2009
    I HAVE NOT BEEN ABLE TO READ YOUR NEW SOLUTION THAT YOU POSTED FOR FIXING MY REFRIGERATOR. WHEN I CLICK TO READ THE SOLUTION NOTHING HAPPENS.
    YOUR WEBSITE DOES NOT RESPOND. WHEN I CLICK THE LINK BELOW NOTHING HAPPENS. CAN YOU NOT SEND THE SOLUTION BY EMAIL? UP TO THIS POINT I HAVE RECEIVED NOTHING OF VALUE TO ME. THERE MUST BE SOME WAY THAT YOU CAN COMMUNICATE THE SOLUTION AND THEN I CAN APPROVE PAYMENT.
    MY GE REFRIGERATOR MODEL #GHS25KGRBBB WILL NOT DEFROST. IT HAS A NEW MOTHER BOARD AND THE HEATER IS GOOD. IT IS ELECTRONICALLY CONTROLLED AND HAS NO MECHANICAL DEFROST TIMER. I WOULD LIKE TO KNOW IF THE THERMISTOR ON THE EVAPORATER BEING FAULTY COULD CAUSE THE PROBLEM. IF NOT THEN WHAT?
    I HOPE AND BELIEVE THE SOLUTION WILL TURN OUT TO BE CORRECT. THAT IS WHERE I WILL START.
    Novelist:
  • 130 Answers
Yes the thermister on evaporater can cause this problem ,actually evaporater coil becomes hot and cool.if the coil only remain become cool and only remain hot.then it will not defrost.and thermister controls the heat and cool functions in evaporater coil.if the thermister is faulty it will not give command to evaporater coil to get cool down or turn heat on the evaporater coil.so its possible that thermister can be faulty. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 27, 2009
    Sniper:
  • 73 Answers
Dear there is a page that contains the detailed solution to your problem. here is the link give below to your solutions.
Best regards.
Posted on May 26, 2009
  • Muhammad Ilyas
    Muhammad Ilyas May 27, 2009
    Dear, click the link blow, that has the detailed tutorial to your problem.
    http://www.appliance411.com/faq/howdefro...
    Best Regards.
Refrigerator part of coil freezing up, what would be the problem?
2) Some refrigerators contain timers that control the self-defrosting heaters. Unfortunately, it can be hard to find the timer, depending on the model of your refrigerator. In most cases, side-by-side refrigerators that have temperature control knobs at the top of the fridge compartment often have the defrost timer located near the thermostat behind the control knobs. It looks like a small, round object with one flat end that has four electrical prongs. It is also often located in the control panel, behind the fridge or behind the foot kick panel at the base of the appliance. Use a flathead screwdriver to advance the timer until you hear a click. This should start the defrost heater. If it doesn't, the timer probably needs to be replaced. Continue to turn it clockwise and a second click will be heard, which turns off the defrost heater. If the timer isn't clicking, simply pull it out and "plug in" a new timer.refrigerators that don't have timers have control panels that control the self-defrosting unit instead. The control panel can sometimes be tested using the controls on the water dispenser or by removing the rear of the front panel to access the controls. A simple press of the button will run several diagnostics that will test your defrost timer, thermostat and heater. The specific instructions vary depending on the model of your Kenmore refrigerator. Consult your owner's manual to run the diagnostics if you have a control panel in your refrigerator.
Read more: http://www.ehow.com/info_12180665_repair-kenmore-refrigerators-coil-freezing-up.html#ixzz2a25eGLEL
tests this steps and fix it. God bless you
Jul 25, 2013 | Refrigerators
Climate Control - Heat and cool work fine. Air flow is directed to defrost /floor. No indication (Sound or sight) that the vacuum diaphrams are being activated. The display on the dash matches the...
Does your vehicle have manual or automatic climate control ? You system is stuck in floor an defrost mode ?
03 mercury grand marquis hvac air flow .-13qahwfdndst2y1hypmr2cdq-4-0.gif Item Part Number Description 1 18A318 Vacuum control motor-floor/defrost door 2 - Defrost air flow 3 18A478 Floor/defrost door 4 18476 Heater core 5 19860 Evaporator core 6 19805 Blower motor 7 - Outside air inlet 8 19A813 Air inlet door 9 18A318 Vacuum control motor-air inlet door 10 - Recirculated air inlet 11 18B545 Temperature blend door 12 18A559 Panel door 13 - Panel air flow 14 18A318 Vacuum control motor-panel door 15 - Floor air flow 16 - Vacuum from the engine intake manifold 17 19A563 A/C vacuum check valve 18 19A566 Vacuum reservoir tank and bracket 19 19980 EATC control
Pull the control panel an check for vacuum
vacuum lines hvac 03 grand marquis-13qahwfdndst2y1hypmr2cdq-4-2.gif Item Part Number Description 1 White Air inlet door 2 Yellow Floor/defrost door 3 Red Floor door 4 Blue Panel door 5 Black Source vacuum 6 - Not used
VACUUM APPLICATIONS CHART-ELECTRONIC AUTOMATIC TEMPERATURE CONTROL Switch Port Vacuum Harness Hose Color Func- tion Manual Override Selector Buttons OFF MAX A/C NORM A/C VENT FLOOR FLOOR/ DEF DEF 1 White Air inlet 2 Yellow Floor/ panel (partial) 3 Red Full floor 4 Blue Panel 5 Black
Source
May 21, 2017 | 2003 Mercury Grand Marquis
Evaporator freezes up and I must remove the freezer's rear inside panel to manually defrost it. Suspect defective electronic control module. Problem began shortly after an electrical storm. Want your...
check the defrost heater under the evaporator core first for continuity with an ohmmeter they burn out,then if this is ok replace the adaptive defrost control
Jun 19, 2010 | Refrigerators
Freezer builds up ice and refrigerator side does not cool properly
Change the defrost thermostat. It you set you back about 25 bucks
Dec 18, 2009 | Audio Players & Recorders
Running to cold, after while evaporator coils are packed with ice even defrost timer ,termostat and heaters are new.
Hello, Most likely you have a bad defrost timer, If you have a mechanical defrost timer it will normally be located either in the control panel inside the fridge or behind the panel beneath the doors. To test this once you have found the timer advance it to the defrost cycle and the wait to see if the heater makes a spitting noise. If the defrost cycle fires up then the timer is bad and you should replace it. If you have a digital defrost timer it will be a circuit board located in a panel behind the refridgerator. locate the tech sheet behind the panel under the doors and force it into the defrost cycle...once again if the defrost cycle kicks in your going to have to replace the circuit board. If you have any other questions please feel free to comment again. Mike
Oct 17, 2009 | Refrigerators
Freezer frosts up and will not defrost itself anymore. Do I need a new defrost timer and/or thermostat? If so, where is the timer/thermostat located in the refrigerator?
It could also have a bad defrost heater. The heater and defrost thermostat are located mounted on the evaporator coil and the timer is usually mounted in the control panel with the control thermostat or in the compressor compartment.
Aug 28, 2009 | Maytag Refrigerators
Model 596.73502203 Making intermittant buzzing sound. Moisture on inside of fridge and freezer. Food in freezer is thawing out.
I believe that your refrigerator may need a new 12002495 or 1184282 Adaptive Defrost Control You can find it inside the fresh food section and behind the controls for temperature. Not sure about the buzzing sound yet but the moisture and thawing of the frozen food points to a defrost problem. Need you to unplug and have a look at the adaptive defrost control. Would not hurt to open the back panel in the rear of freezer and defrost if needed and need someone to check the defrost heater and defrost thermostat. Sea Breeze
Aug 21, 2009 | Kenmore Refrigerators
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
My freezer is not as cold as it should be, and the ice maker is making ice, but very slowly. Also the panel is blinking "sevice". It is a model 632/f 2 side by side. I'm not sure of the age, because it was...
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
