Vidal Sassoon VSCL816 Beard Trimmer Logo
R
Rosa-Lynn Roberts Posted on Jan 10, 2014
Parts replacement How to assemble the head?
  • Rosa-Lynn Roberts
    Rosa-Lynn Roberts Jan 10, 2014
    vidal sasson VSTR8152 BEAR TRIMMER
2helpful
I would like to replace the headlight assembly of a 2008 Silverado. I've located 3 bolts and removed them but am unable to remove assembly. Is it possible to replace the head light assembly without...
There is a little aluminum stick in the assembly holding it in. On the top of the headlight twist the stick and remove it. It will look like a tent stake. Remove this stick and then the head light assembly will almost fall out.
3helpful
2answers
I need to replace the front turn signal light socket on a 2000 Chevy Venture, but i don't know how to get it out and i can't find a replacement. How do i get it out?
There are detailed instructions in the the manual. If you do not have a manual, here is how to do it (directions assume removing drivers-side headlight assembly and viewing the area from the front of the van): Remove the thumb screw on the left side of the headlight assembly as well as the thumb screw on the top of the head light assembly. The third thumb screw simply anchors the turn-signal assembly to the head light assembly. Initially, just loosen that screw. The whole assembly is now loose but still held in by two plastic posts on the bottom of the headlight assembly and two plastic posts on the end of the turn-signal assembly closest to the fender/wheel area. Pull the whole assembly kind of up, out, and down. It takes a bit of juggling but it will come out. Once the whole assembly is out you can separate the turn-signal assembly from the head light assembly and put the headlight assembly back in place. To separate the assemblies remove the third thumb screw (if its too tight to remove by hand you will need a Torx screw driver of size T-30; if you don't have a Torx a small flathead screw can work); also, you will notice the hidden clip that is the final anchor holding the turn-signal assembly to the head light assembly. Use a flat-head screw driver to release it. Now the units should be separated. To remove the turn signal bulb socket from the turn-signal assembly, simply turn it counter-clockwise while pressing down on the safety clip and pull it out of the back of the turn-signal assembly. The owners manual lists the type of bulb. It should be an amber 3157. The bulb pulls straight out of the socket.
Replace the bulb. Place the socket back into the turn-signal assembly (turn it clockwise until the safety clip snaps). Replace the Headlight assembly (two thumb screws and the two plastic alignment posts anchor it), but do not tighten the screws until the turn-signal assembly is in place. Replace the turn-signal assembly by first aligning the plastic posts and then anchoring it to the head light assembly with the third thumb screw. Make sure everything is aligned properly and tight all the thumb screws. An experienced person can probably make this change, start to finish, in 15 minutes. First timers will probably take 30 minutes as it takes some time to understand how the designers anchored everything.
Good luck and thank you for using Fixya
3helpful
2answers
Norelco Spectra 8 Model 8894XL: Need a new Razor Head Assembly
It sounds like you need a new "head holder". These often wear out over time and fall apart. You will find a replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-spectra-sensotec-head-frame-with-hinge-p-329.html
1helpful
2answers
How difficult is it to replace the front head light assembly? My are very cloudly and I would like to replace them if it is reasonable.
Hi:
Your head light assemblies have lenses that are made out of polycarbonate, and they usually can be restored to like new condition with a kit from an auto parts store, and a little elbow grease...All for about $40.
Considering that the light assemblies could cost $200 each
Magenta print head reseat.
i'm sorry to be the bearer of bad news but it sounds like your carriage assembly is bad. the slot that holds the magenta cartridge is defective.have the carriage assembly and trailing cables replaced. this should resolve your problem. these parts are becoming harder to find because of the age of the printer. carriage assembly part number is C6074-69388. trailing cable is C6074-60418 making the assumption this is a 36" plotter. also you can try cleaning the contacts on the carriage assembly. good luck!
Sony Audio Head Part #??
You need Head Assy in Deck A with following part number...
X-4953-985-1 BLOCK (A) ASSY, HEAD (DECK A)
Above part is available in Part Store.
Top Vidal Sassoon Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
