Question about Samsung HP-R5052 50 in. Plasma HDTV
Tv screen is black but audio is fine. What does that mean?
  • Samsung Master
  • 5,568 Answers
Since you still have audio, the main power supply is functional unless your set does not have a separate high voltage power supply for the plasma tube.
Pull the AC plug and allow the set to sit for at least a few hours, overnight is best. Since these are customarily separate supplies (one for the low-medium voltages, another for the high voltage), open the lower rear of the set where the hardware is concentrated. Look for an assembly that seems to be related primarily to the plasma tube; this will be the high voltage supply.
If you do not find a separate board, the high voltage supply that has failed will be combined with the lower voltage sources.
In either case, you need to call Samsung with your model number in hand and tell them you need a replacement power supply for that set. 9 years? They may not have any but may offer to accept the supply for repair or refer you to an independent services company that specializes in repair of subassemblies.
If you have no burn-in (shadows, when the power is off) of the plasma tube's phosphor, it is still worth repairing. Frankly, I'm somewhat amazed that this failure didn't happen 5 years ago.
Power supplies in general do not need any alignment so unplugging cables (and these are normally of different sizes and not interchangeable) and removing the board mechanically is something about anyone can do.
If they offer to sell you a new supply, expect <$200 US; a repair could run to $75-$150 US.
If you can find a new one or a 'pull' from a working set, don't pitch the old one out, it will still be repairable.
'Pulls' can often be had here"
Jimmy's Parts
Posted on May 26, 2009
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
Sony bravia KDL-40V4100 audio and picture cycling on and off
I'd say about the blinking to a black screen would be your cable provider. As for the stripes that means that your board panels can be going bad, you can try updating the firmware of the TV to help but if that doesn't work you're getting very close to full failure on the TV.
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
Toshiba Regza screen is black but audio works
I unplugged everything and then reset-up the tv, dvd player, audio, and other components.
Dec 29, 2008 | Televison & Video
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HP-R5052 50 in. Plasma HDTV Logo
592 people viewed this question
Henry  Thomas
Henry Thomas
