Question about Kenmore 57029 Side by Side Refrigerator
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no longer freezing. Any suggestions?
Sounds like your compressor is not starting due to a faulty "starter PTC" a.k.a. start relay. Or a faulty compressor. The buzzing noise you hear is the compressor trying to start. When it's windings overheat, an internal cut-off switch "clicks" off until it cool down.
Then the cycle repeats.
Posted on Feb 27, 2010
    Problem Solver:
  • 5 Answers
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
Posted on May 31, 2009
Recently, our Kenmore side-by-side refridgerator starting making a very loud humming, almost grinding, noise. It is loud enough to be annoying from another room. After checking this several times, it...
Look under there and see if any junk is blocking the airflow causing the condenser fan motor to howl.You can oil it with zoomspout oil. It is safe for refrigerators. Don't use WD-40 (flammable) Give it a good clean and verify the fan is moving the air down there. Just cleaning it greatly improves airflow and cooling efficiency. Let me know how it does. Give it a day after cleaning.
Aug 08, 2011 | Kenmore Side by Side Refrigerator
I have a kenmore side by side refrigerator freezer. It's about 15 years old. Recently the freezer has started making a loud humming noise. HELP
Good day,
The most common reason for noise is the fan motor in the freezer compartment.
Remove the screws from the rear panel in the freezer compartment and inspect the fan motor. Replacing it is a fairly easy nuts and bolts procedure. The motor should be available at most appliance parts houses.
kenmore is a trade name for Sears appliances. It was made by either Whirlpool or Frigidaire.
Sep 06, 2010 | Kenmore 57029 Side by Side Refrigerator
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Has anything changed in the cooling? Can you locate the model number on your refrigerator.The noise is coming from under or inside the refrigerator or freezer? Let me know those few things and we will find out whats going on, Thank, Sea Breeze
http://servicepartstec.blogspot.com/
May 17, 2009 | Kenmore 57029 Side by Side Refrigerator
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
1,140 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
