Question about Lisle Serpentine Belt Tool
How do I release the tension belt on a 1994 chevy caprice
  • 37 Answers
Hook onto the bolt of the pulley on the end of the belt tensioner and pull to the passenger side. It should release the tension to get the belt off. Its probably a size 15 or 16 and it will only go one way to release tension. If this helps let me know by hitting the button yes this was helpful =)
Posted on Jun 22, 2009
5.7l. Where can I get a serpentine belt (installation) diagram?
To get the diagram Google
Year Make model serpentine belt
And look at the images tab.
To release the tension lever it with a socket extension bar. Or you can put the belt on the tensioner and lever the belt onto a more accessible pulley.
Jan 31, 2016 | 1996 Chevrolet Caprice
Air flow sensor
M.A.P. Sensor: What and where? ('91 Caprice) - GM Inside News Forum
www.gminsidenews.com/.../m-p-sensor-what-where-91-caprice-25061/
Jan 7, 2006 - 13 posts - ‎8 authors
I have no idea what it is, and where it is located. The part costs $30. ... It uses this sensor to determine the density of the air, and in conjunction with the MAF sensor gives the pcm info for air fuel mixture. With the readings from ...
1992 caprice stalling problem - YouTube
? 1:52
https://www.youtube.com/watch?v=JeAG5EklyUc
Sep 5, 2013 - Uploaded by TheUnpredictableAnalyticalOriginal
How To Fix Or Prevent Stalling, Surging Or Rough Idle, Cleaning Throttle Body and MAF Sensor - Duration: 16 ...
How to change Map sensor connector, Terminal repair and ...
? 4:47
https://www.youtube.com/watch?v=9MavnVA6UO0
Dec 8, 2012 - Uploaded by Ghetto Wagon
How to change Map sensor connector, Terminal repair and release tool .... How To Clean a Mass Airflow ...
Where is the mass airflow sensor on a 1992 chevy caprice ...
www.fixya.com/.../t13501048-mass_airflow_sensor_1992_chevy_capric...
Jul 5, 2012 - where is the mass airflow sensor on a 1992 chevy caprice - Chevrolet 1992 Caprice question. ... SOURCE: need the location of the mapping sensor for a 1994 chevy caprice ... Where is oxygen sensor on 92 chevy caprice.
Where is mass air sensor located on chevy caprice 1989 ...
Dec 12, 2015 | 91-96 Chevy Caprice Billet Grille Grill 95...
What would cause the front brakes stick on 92 chevy caprice
There are three main typical causes of what you describe:Binding calipers, binding proportioning valve, and master cylinder not releasing fully.
At issue is what, exactly is happening....can you describe please?
Doc
Oct 22, 2011 | 1994 Chevrolet Caprice Classic
I need to know how to change the serpentine belt on a 1994 chevy cavalier
    • 1 Open the hood, and locate the auto-tensioning bolt in the center of the pulley system. This bolt will be in the center of a pulley that does not appear to be connected to any component.
    • 2 Turn the auto-tensioning bolt clockwise with a socket wrench to release tension on the belt.
    • 3 Slide the belt off the pulley system.
    • 4 Orient the new belt on the pulley system according to the belt path printed on the underside of the hood and next to the hood latch mechanism on your Cavalier. Leave slack in the belt around the tensioner pulley.
    • 5 Slide the belt over the tensioner pulley while you have the auto-tensioner pulley bolt turned clockwise as far as it will go. Make sure that the belt is sitting centered in all the various pulley grooves on the pulley system.
    • 6 Release the tension pulley bolt, and apply tension to the belt. The auto-tensioner will automatically apply the correct amount of tension on the belt.
Oct 05, 2011 | 1994 Chevrolet Cavalier
I have a 1994 chevy cavalier 2.2, i replaced the belt tensioner, how do you set the tensioner so it will keep the belt tight? I loosened the bolt and got the belt tight, then i tested it and the belt...
U do not loosen any bolts to adjust tension.tighten all bolts first.Then with a 3/8 ratecht in the slot of the belt tensioner rotate the tensioner until you can install the belt correctly.then release the tensioner and take out the ratchet.
Dec 02, 2010 | 1994 Chevrolet Cavalier
How do I loosen the tension on the belt in a 1995 Chevy Caprice so I can replace the alternator?
Click on the following direct Link. It has several Serpentine Diagrams; one of which matches your specific engine and options (ex: AC/No AC etc).
Regarding HOW:
Standard Rule to Removal the Serpentine Belt:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT OR OPENING (3/8ths or 1/2 inch square opening) away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys
Standard Rules for Installing the Serpentine Belt:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Let me know if this helped...
http://www.2carpros.com/car_repair_information/year/1995/make/chevrolet/model/caprice/1995_chevrolet_caprice_drive_belt_routing_diagram.htm
Mar 18, 2010 | 1995 Chevrolet Caprice Classic
I am trying to install altenator in 1989 Chevy Caprice and I cannot loosen serpantine belt
Put a wrench on the bolt in the middle of the belt tensioner and push down to release the tension on the belt. It is spring loaded. Do the same to reinstall the belt.
Jul 15, 2009 | 1989 Chevrolet Caprice
Tensioner Pulley
LET CAR BE COOL YOU WILL NEED ANEW BELT, OF COURSE. TOOLS: APPROPIATE CUBES AND RATCHED SET. AND AN ADDAPTOR TO FIX RATHED TO THE SQUARE HOLE IN TENSIONER PULLEY. REMOVE UPPER SIDE OF FAN COVER (YOU WILL CHECK PRINTED INFORMATION ON IT TO ORIENT YOU ON THE BELT CORRECT POSITION) RETIRE REST OF THE OLD BELT PLACE THE NEW BRLT ON POSITION AND PLACE THE RATCHED WITH THE ADAPTOR IN THE SQUARE HOLE IN SUCH WAY YOU CAN PULL THE PULLEY WHILE THE BELT IS TAKED TO ITS POSITION. GENTLY RELEASE THE PULLEY AND CHECK BELT IS ALLIGNED IN ALL THE PULLEYS. REMOVE TOOLS AND START ENGEINE. CHECK BELT DOESN'T MAKE STRANGES NOISES OR MOVEMENTS. TURN OFF ENGINE, PLACE THE UPPER SIDE OF THE FAN COVER AGAIN
Feb 18, 2009 | 1994 Chevrolet Caprice Classic
Lisle Serpentine Belt Tool Logo
299 people viewed this question
Top Lisle Hammering Experts
john h
steve morris
steve morris
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
