Question about Bosch Dryers
Clothes dryer stops spinning before clothes are dry
My dryer stops spinning after 10/15 minutes.....i can hear the humming of the motor.....sometimes on opening and closing the door it may start again or most instances i will have to wait about 30 minutes to restart it...it is heating very well
    Scholar:
  • 91 Answers
Sounds like a bad cycling thermostat!
Posted on May 27, 2009
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
Thanks
Vic
May 15, 2009 | Dryers
Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Apr 29, 2009 | Whirlpool LEQ7030KQ Electric Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Dryers Logo
310 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
