Question about Toshiba Satellite Pro L300 Notebook
My toshiba L300 keeps freezing and shutting down
My laptop just keeps freezing doesnt matter weather I open a program or not sometimes it freezes while its starting up
  • 674 Answers
How many MB YOUR RAM/ may you have lowest of Ram 256MB/ or 512MB only.....that why freezing your laptop. make it upgrade your RAm ...now adays all programs are updated to new versions.. if you using os xp -- sp2 or sp3 or higher than.. atlest you have minimun of ram 1 or max. 2gb..if VISTA min. 1 max 2 or 3GB
also alot of viruses.spyware or all unwanted programs. programs can make slow of operating system....., check first your programs then hardware .. change it if nessesary.
Posted on May 26, 2009
Why does my laptop keep freezeing up and shutting down, I did a virus scan and its ok
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
These two tips are found to be very helpful to fix the laptop shutdown problem.
For complete optimization use system utility tool Reginout. WebRepOverall ratingThis site has no rating(not enough votes)
Dec 19, 2012 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba L300, when ever i connect the Adapter Chager, the laptop freezes and it give me a blue screen background (not BSOD). The laptop' working fine when it's running on battery powe
It sounds as if you need a new charger. Try removing the battery and start the machine with just the charger. If that works then it may be a new battery you need. Some toshiba notebooks have a 'power saver tool' preinstalled, which is used to monitor battery performance. You can download a copy here:
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
Not sure if it will be compatible with your machine, but maybe worth a try as it could be a corrupt program causing the problem.
Mar 29, 2012 | Toshiba Satellite Pro L300-EZ1004X...
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba laptop restarts randomly when it plugged.,and again restarts sometimes it will shut off .but no problem occurs when in batterry power.please help me to solve this problem.
Many models of Toshiba Satellite laptops have a capacitor called NEC/TOKIN Proadlizer which loses its capacitance with time and hence laptop freezes, shuts down or restarts when AC is plugged in. One needs to replace this cap as shown here:
http://gs138.photobucket.com/groups/q251/S1BXDWUERU/
Jun 09, 2011 | Toshiba Satellite Pro L300 Notebook
My Toshiba keeps freezing up. Esp when moving from program to program.
DOWN LOAD AVG.COM FREE VER RUN A COMPLETE SCAN OF YOUR WHOLE COMPUTER AND IT SHOLD RESOLVE YOUR PROBLEM THEN JUST CLEAN UP A LITTLE WITH SCANDISK OR DEFRAGMENT THE DRIVE.
Dec 10, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite l300-1aq laptop is freezing within minutes of start up? I am running Windows Vista. How can I root cause the issue?
When you power up, turn the notebook so you can see if the cooling fan is running.
It sounds like the self protect shut down from over heating.
Feb 01, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop freezes
first you should go into safe mode and get a start up manager program and stop the programs from running at start up ,clean your computer with all in one cleaning software i have auslogics boost speed, upgrading your ram would help making it faster, get rid of the unwanted programs you dont need, get rid of the unwanted files you dont need and go to task manager and stop the unwanted processes from running thats just a few things you could try so it wont freeze up and it will be faster i clean my computer weekly so it doesnt slow down bc everytime you go on the internet it adds files to your computer that you dont need after your done. Hope i helped solving your freezing problem
Jun 01, 2009 | Toshiba Satellite A300-0CF035 Notebook
Rotating the volume wheel on my laptop freezes Windows
My toshiba satellite l300-1aq laptop is freezing within a minute of start up? How can I root cause the issue?
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
508 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
