Question about JVC GR-D250 Mini DV Digital Camcorder
JVC-GR-D347U camcorder in safe mode-04 code, is it worth $ to fix it?
CANT GET THE CAMCORDER OUT OF SAFEGUARD MODE I have a JVC GR-D347U Mini DV digital camcorder It is in safe mode code 04 says to eject and reinsert tape, it has been like this for 5 days, just was wondering if it is fixable or if the cost to fix it would be the same as buying a new camcorder?
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
JDeRuvo
  • 48 Answers
SOURCE: JVC Camcorder Model # GR-D270U
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
SOURCE: Problem with JVC Mini-DV Recorder - Model GR-DVL100
Hi KeeKee,
I have the same camera but I donot have the driver to download video onto computer. I use window XP. Can you help if you have the driver?
Thank you
Posted on Dec 27, 2007
kala
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
SOURCE: E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Posted on Oct 16, 2008
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
Camera seems to think that the lens cap is on, there is no image (and no the lens cap is not on)- jvc mini dv camcorder gr-d347u The message "Lens Cap" appears when the camera is turned on, there is no...
There are 2 possibilities for that symptoms in JVC GR-D347U camcorder is either aparture in lens mechanism is stuck and does not pass image towards CCD Imager OR ccd imager itself got bad.
Qualified camera tech can fix it because it requires expertise.
If you want to fix it, download service manual from HERE for small fee, that will help you how to disassemble/ apart camera and part info etc.
Thanks.
Aug 13, 2009 | JVC GR-D347U Camcorder
Jvc mini dv camcorder won't record
This may sound crazy but I fixed mine by putting it in the microwave for 8 seconds along side of a shallow dish with about 1 tsp. of Hot Sauce!
May 04, 2009 | JVC GR-D347U Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Safegaurd mode
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
265 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
