Question about Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television
Green gun is bad
Thank you for your advice.  I opened up the back of the tv and the red and blue worked but the green wouldn't go on all thew way.  How complicated and how expensive is it to repair the green gun?  is it something i could go buy something for, uninstall and install myself?
    Genius:
  • 1,153 Answers
With the right instructions you could DIY. I would get the error codes first by looking on these threads for it or go to ctechnicians.com
Posted on Dec 30, 2007
54cm CRT tv tube green
CRT color television have three color "guns"; red, green, and blue. This is where the term RGB comes from when discussing computer CRTs. If you are getting only green, something is preventing the red and blue guns from working.
Aug 08, 2016 | Televison & Video
I have a JVC model AV27320 standard TV. The picture is dark and the tint is off. The colors you can see are blue and red. Tried adjusting tint and brightness from the menu and no significant change. ...
It is one of two things the picture tube is bad and the green emission is very low or the green gun is open, the second possibility is the video driver or output is shorted on the video board "plugged in the back of the picture tube"
Mar 03, 2011 | JVC Televison & Video
Color is bad especially colors like orange and the white on peoples teeth is black most of the time andthe picture is not clear
HI, thank you for visit fixya.
Common problem on this set .
Picture tube liquid is dirty.
Mostly in crt green and crt blue.
Do you have electronics skills?. If so, open the TV ( back cover), you will see green,blue and red gun. After turn on your tv, select any channel or video signal, cover with piece a paper two guns at the top ( any), and see how look the picture in the front, try one at time, ( press menu on remote control and see leters-clear). I am sure the green and blue will be no clear. all the time red tube is fine.
REPLACE COOLANT LIQUID PROJECTION ( solution).
I will be here for any quetions.
Thank you
Dec 01, 2009 | Philips 60PP9352 60" Rear Projection...
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I heard a pop in the TV and then the screen went red. I can still hear it and watch it but everything is red. Is it a bulb that needs replacing? If not, what is it? Can I do it myself or will I have to...
Several failures can cause a red picture but it sounds like if you are connected from the source with component video cables(red,blue,green)you may just have a bad cable,but you may have had a blue and/ or green projection gun failure,which would cause the red gun to over power the other colors(blue/green), if this is the case definently not worth the cost to repair, you have to replace all three guns at the same time costing $500+ to repair, invest that towards a nice new LCD panel TV. Good luck !
Nov 26, 2009 | Akai PT5492S 54" Rear Projection...
Blue gun lites but no picture from it
you should be able to go to any used appliance shop and get what you need. most of them carry on hand parts or can order whar you need
Dec 25, 2008 | Sony KP-51WS500 51" Rear Projection...
No color on tv screen
Repalce your tubes they are bad Red,blue,and the Green.
Dec 19, 2008 | RCA Televison & Video
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
Sony tv color screwed
Did you try any adjustments on your own? It looks like the Blue output Gun is not working. Most likely the Blue Output Transistor is blown. Nothing you can do, unless you know Solid State Electronic. I advice that you seek professional help.
Dec 13, 2007 | Televison & Video
Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
