Question about GE GSH22KGR Side by Side Refrigerator
My freezer's model is GSH22KGRB side by side, it's not cold enough and the keypad for adjusting temperature is not working either, so I could not read or adjust the level of temperature.
SOURCE: Not cold enough
I opened the bottom panel at the back of the fridge and cleaned the coil because it was completely covered with dust and lints and less than an hour later the fridge side temp started going down and the freezer took five hours for the temp to start going down when we didn't open it for that much time. It's back to factory setting now and thanks for the blogs that I read that I was able to try different possibilities. Your site is very helpful.
Posted on Mar 21, 2009
kram26
  • 544 Answers
SOURCE: refrigerator does not get cold enough 50 degrees.
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks.
Posted on Mar 31, 2009
  • 291 Answers
SOURCE: Maytag freezer & refrigerator not coold enough
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. I feel heat/warmth on the front edge of my refrigerator....why?
Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
clean the condenser coils as a dirty condenser can make the tubing hotter than normal
- check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
- If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
Posted on Apr 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
Healeyman
  • 1198 Answers
Setting the control to 9 may make the freezer ice up too much to work right. You can start with a manual defrost. That takes a long time, because the ice is below the freezer liner, stuck in the coils. You'll have to move your food elsewhere, like a cooler. I always take the freezer apart to get at the coils, use a hair dryer to melt the ice. Then you can check the defrost coil, it's like a toaster element. After all that, check the defrost timer too. It's usually down by the compressor area, about the size of a cell phone. It has a small dial on it that only turns one way. Mark it when the fridge is on with whiteout to see if it moves. It moves real slowly, so you will have to wait a half hour or so.
One way to speed up a defrost is to turn the dial on the defrost timer until it clicks. Then the compressor will turn off and the defrost coil will turn on. The freezer fan should be spinning. Feel the output from the freezer fan- anything? If no flow, you're iced up. Keep checking for flow, eventually it should get cold. When you get good airflow, and maybe it's not so cold anymore, you might be defrosted without having to take the whole thing apart. You may have to turn the dial more than once, if the compressor comes back on before you're defrosted. You can help the defrost with your hair dryer thru the vents in the front of the freezer, but not too hot, you don't want to melt any plastic.
Temperature playing up going up not down
Refrigerator Not Cooling Enough - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
How To Fix A Refrigerator and Freezer That's Too Warm ...
www.partselect.com/Repair/Refrigerator/Refrigerator-Freezer-Too-Warm/
If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
Nov 21, 2015 | Refrigerators
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer too cold, has frost on food and frig is freezing food on Kenmore side by side frig/freezer. Model 1065438300 Ran test sequence on front panel and all is inputs and outputs display that they are...
There should be separate temperature controls for each side correct?First,try turning the freezer side to a warmer temperature setting.Not just a little but a lot.It takes about 24 hours for it to adjust to the new temperature,but you can check on it every couple of hours.If nothing changes,it is most likely the thermocouple within the freezer half.It basically reads what temperatureyou want,reads what the current temperature is,and tells the refrigerator when to send more cold air.If there is a noticeable change,we will have to look elsewhere.A thermocouple is basically a metal rod with 2 leads coming out of it into the back of the refrigerator somewhere.It may also be small sometimes,or hidden under a plastic cover.Google thermocouple and it should show some pictures of it.They are for the most part the same with only slight variations in length or width.Greg
Nov 04, 2010 | Kenmore 53642 / 53644 Side by Side...
The freezer is working but the fridge part is not blowing any air. Model #BR22TL, MFG No P1196710WL and S/N 9801166059. I have check for continuty and all readings are o.k regards Elton Hinds
The refrigerator gets its cold air from the freezer, usually through a flap between the two sides. First make sure your temperature control has not been turned down in your refrigerator. You might have to defrost your freezer to get the flap working again, which could mean something in the defrost circuit is bad.
Also note that
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Hope this works and Good luck in fixing....
Jul 28, 2010 | Amana ARS2661B Side by Side Refrigerator
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer freezes up GE side by side #GSH22KGRB
Hi, the defrost thermostat is bad. replace this and it will fix this unit.
May 22, 2009 | GE GSH22KGR Side by Side Refrigerator
Vegetables freezing
Most side by side refrigerators use the freezer to supply cold air to the refrigerator side. They use a duct through the wall between the two sides to let COLD air come into the refrigerator. That cold air will be blown upon the drawers at the bottom, where you are storing your vegetables.
There are two adjustments - or three, depending that will change how the air comes through. The freezer control will set the base temp for the freezer, and thus the temp of the air coming into the reefer to cool it down. The reefer can have a movable vane that increases or decreases the amount of air flowing in from the freezer, the vane being operated at the command of the refrigerator temperature control. Some have a movable plate that limits the flow of air on a fixed basis.
Set the freezer for 0F. Adjust the refrigerator setting, starting in the middle of the range, until a thermometer on a middle shelf, will read at 40F. Take your time, and check once an hour or so, to let it stabilize.
Make sure that you are not blocking airflow in the refrigerator, as the air must circulate to avoid too low a temperature in spots, such as you are experiencing.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Jan 18, 2009 | Frigidaire FRT18G6J Top Freezer Side by...
GE GSH22KGR Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
