Question about Alcatel Newbridge MainStreet 3612 Multiplexer
Cant find craft cable
Can someone give me the pin out for a newbridge alcatel mainstreet 3612 craft terminal cable?
2 Suggested Answers
SOURCE: Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
Posted on May 23, 2007
We connect 8 analog lines to a 3612 on one end compressed lines to 16 k each accross a data circuit then break them back out on a 3612 on far end. Calls will be up for a minute or 2 then drop. Call...
There are many reasons why the call will be dropped. The call will be dropped when you aggregate link between the nodes fails, if this is not the case monitor the connections on the node and see if the connections stays up. If I would guess it could be the PABX that is dropping the calls and not the nodes.
May 23, 2011 | Alcatel Newbridge MainStreet 3600...
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
Mar 03, 2010 | Alcatel Newbridge MainStreet 3612...
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
Mainstreet 3600
I will send you the info on your mail address if you still need it.
Apr 25, 2009 | Alcatel Newbridge MainStreet 3600...
Can't access to alcatel 3600 node managment station from faceplat
SP1 is belong to VT100
VT100 RJ45 DB9 1 8 2 7 3 2 4 3 5 5 6 4 7 6 8 --
Jan 09, 2009 | Alcatel Newbridge MainStreet 3600...
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
Newbridge 3612
yes, you can shut down and relocate with no adverse affects.
Apr 28, 2008 | Alcatel Newbridge MainStreet 3612...
Mainstreet 3600 cpss does not work
no tengo el manual en electronico por favor guiarme sobre el mismo en version español
Dec 13, 2007 | Alcatel Newbridge MainStreet 3600...
Apr 04, 2007 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3612 Multiplexer Logo
126 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
