Question about Philips Magnavox 27MS343S 27" TV
Blocked by autolock
Picture gets blocked
  • fougzki May 11, 2010
    This could help you.
    http://www.retrevo.com/support/Philips-2...
  • Jeremy  Sluder
    Jeremy Sluder May 11, 2010
    Can you go into more detail?
    President:
  • 814 Answers
Follow this web link http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602164521_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals to the magnovox website to see a copy of the owners manual. Look on page on page 24 titled Blocking Programming With Movie Ratings. You can turn off all the ratings with the instructions in the manual. If this does not help you with your problem you can call Magnavox customer support at this telephone number 1-800-705-200 give them the model number of your television and tell them the problem you are having with the channel blocking. I hope this information helps you with your problem.
Posted on Jun 02, 2009
Smart Lock Magnavox TV
Magnavox sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
ON". The v-chip is Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE now reset.
Jun 14, 2012 | Akai Televison & Video
How do I unlock magnavox NB500MG1F?
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
May 04, 2012 | Televison & Video
How do i reset my parental pin
Hello
OK.
Jun 28, 2011 | Philips 50PF9956 50 in. HD-Ready Plasma...
My phillips television is locked
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
OK.
Apr 21, 2011 | Philips 28PW6506 28" TV
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
Unlock code for 3256
Hello
OK.
Feb 10, 2011 | Philips Televison & Video
I need unlock code for tv-2151TXF PLEASE HELP!
Hello
OK.
Jan 06, 2011 | Philips 30DV693R 30 in. TV/DVD Combo
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
I have a old 26 inch tv and its blocked can you give the code for it please
Hello
Philips sets use a four digit code to control the V-chip. The override code for Phips Tv is ( 0711 ), although the set may say "Incorrect Code" for the first time to TRIK you. If "Incorrect Code" is displayed simply enter 0711 again. To use it Hit the Menu key to get to the menus, go Up and Down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right" arrow" key on the remote control hanset. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK Menu go to "BLOCK", and push the "Right" arrow key. Go to "BLOCKING OPTIONS' and press the "Right arrow" key. Go to "MASTER DISABLE" and press the "Right arrow" key, so that it says "MASTER DISABLE ON". The V-chip is now reset.
Ok
Nov 29, 2010 | Philips Magnavox 27MS343S 27" TV
The tv is blocked by autolock
I faced this same issue......the override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Apr 27, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
