Compitable processor with Foxconn 45GM/45CM
Hi, I have the the motherboard of Foxconn 45GM/45CM and the processor 2.00 gigahertz Intel Celeron 440 and i would like to upgrade my processor to might be duo core or quad core if possible. But, I am not sure how can i find it out which processor would be compitable with this board. Please do let me know about any relavent information....
Thanks Yudi
    President:
  • 688 Answers
Here is FoxConn website and shows what processors would be compatible.
You may need to upgrade the bios, and remember.
If you go to high your other components in your machine may not be compatible.
i would try and contact support at foxconn and see what they say about upgrading.
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=45CM&cputype=Intel
Posted on May 26, 2009
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Does dual core processor support Foxconn P9657AA-8EKRS2H mother board
The Foxconn P9657AA-8EKRS2H motherboard has a LGA 775 Socket. It will support Intel Core 2 Quad, Core 2 Extreme, and Core 2 Duo processors with an FSB of 1066 (800MHz). Thus is should support the dual core 775 processors. (Some Pentium 4, Pentium D and Celeron D CPUs may also be compatible with the board.)
I hope this helps.
May 06, 2012 | Foxconn P9657AA-8EKRS2H (6938279104065)...
On my foxconn 45gm/45cm and im using windows 7.my windows performance expirience is 3.2 on gaming graphics but it doesnt play need for speed wanted to perfection
with need for speed and any other game that is heavy on graphic is all about graphics card. it's not enough to have a good CPU and plenty of ram - you need to have a good GPU too and a fast HDD/SSD. i'd suggest to upgrade your GPU and RAM
Mar 16, 2012 | Foxconn 45CM-S Core 2 Extreme/ 945GC/ FSB...
Foxconn 45gm new cpu monitor now wont work?
sounds like your new processor is faulty or dose not support your board if your old CPU works fine then take your new one back after checking its compatible also with some boards you need to update your bios to get full use of it i have had similar problems that an update solved first if not get your new CPU replaced hope this has been of help
May 21, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Can i upgrade a dell vostro 200 computer to a q8400 cpu
unforntuately, these are the only type of processors that the vostro motherboard supports
Intel® Core2 Duo processor
Intel® Pentium® Dual-Core processor
Intel® Celeron® processor
the one that you were asking to use is not compatible since it's a Quad processor.
Oct 10, 2009 | Foxconn Computers & Internet
I need a driver for my foxconn 45gm/45cm mobo.
http://www.foxconnchannel.com/support/downloads.aspx
Aug 02, 2009 | Foxconn Computers & Internet
Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Jul 26, 2009 | Foxconn Computers & Internet
Board: Foxconn 45GM/45CM Serial Number: UYQN73503042 Bus Clock: 200 megahertz BIOS: Phoenix Technologies, LTD 6.00 PG 07/03/2007 This is my motherboard, could you please tell me what kind of graphic...
when you go into a computer store to buy a graphics card they know what kind of graphics card you need just take your motherboard info with you.
Nov 02, 2008 | Computers & Internet
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
What i have as agp or pci and whats the best graphics card i can get without getting a new pc
An AGP video card would provide a better video performance than a PCI video card.
Jun 06, 2008 | Foxconn (865G7MC-ES) Motherboard
Computers & Internet Logo
2,354 people viewed this question
David Payne
David Payne
