Question about Homelite Garden
How to remove clutch on model z830sb
How do I remove the Homelite trimmer clutch model z830sb?
  • 420 Answers
The clutch interior must be turned the same direction as the engine to loosen (reverse threads), tapping with a screwdriver and hammer usually does the trick. When you install the new clutch make sure you apply an anti seizing compound to the threads.
Posted on May 26, 2009
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite Z830SB Brushcutter. I use it with the blade attached rather than the line, for cutting. It starts fine, but it does not engage (i.e. the shaft does not spin...so there is no rotation in...
the inner shaft could have broken, which is the case a lot when using the blade vs the string remove the shaft from the motor, and spin the inner rod and see if the blade turns, if it does check the end of the rod and see if its damaged in anyway , if the blade doesn't spin, the shaft has broken and will need replacement
Jul 03, 2011 | Homelite Garden
I need a gearhead for a homelite z830sb string trimmer. the part # is A04836C. Homelite no longer makes or stocks it. Apparently they don't think their products should last or can last 14 years. ...
I have seen exactly what you mean. The part is listed as obsolete and has been superceded by another part # UP06970 that is also out of stock NLA (no longer available). But somebody, somewhere on the net has one of these. These guys list it, but it is out of stock...at least it is not listed as no longer available. Your part is the gearhead at the top of this page. You can contact these guys for more information and when it might become available to you if they order you one. I know just how frustrating this is. Anyway, these guys list your part with the new part number.
http://www.cmsmallengines.net/trimmer-parts-c17/homelite-1-2-3-4.html#2
Post back if they can't help you soon and I will keep looking with you!
May 22, 2011 | Homelite Garden
I was given 2 weed eaters, the z830sb, and the d630cd. I need to know what the gas and oil mixtures are for these units.. Thanks Jim
32:1 should be a good mixture for the homelite weed eaters. here is a thread on it, hope it helped Tim:
ttp://forums2.gardenweb.com/forums/load/tools/msg1011591014681.html?13
Apr 24, 2011 | Homelite Mighty Lite Lawn Trimmer
Does a homelite st-175g have a clutch?
I couldn't find a parts breakdown for your exact model, but on the ST-185, the clutch is optional. If you can remove the handle from the front engine cover (probably 4 Torx screws) and look inside, there would be a round 4" or so metal drum with the clutch inside right near the front of the cover. It is not hard to spot. Post back if needed.
Nov 17, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite Z830SB weed eater and the pull cord broke. How do I get the molded cover off so I can replace the pull cord
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Loosen it. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit with handle installed with the new rope.
Sep 08, 2010 | Homelite Garden
Trimmer won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Housing removal outside the Homelite clutch
You must first remove the rear housing, then the shaft to access the clutch area.
May 26, 2009 | Homelite Garden
I am trying to find a parts list layout for a z830sb homelite. I purchased a replacement head but there seems to be an adapter missing at the base of the angle head.
Here is a web site with the diagram for you. you need to first go to this site: www.jackssmallengines.com. then, click on the parts database link near the top of the page. it will come up to a new screen where you have to click on another button to get into the parts diagrams part. from the drop-down menu, select Homelite Consumer products, then click the model number tab at the top of the page. type in "Z830SB" and hit enter and it should bring up a menu for you to choose which diagram you need to look at. Hope this helps. Let me know if you need any more help. I would just give you the exact site, but it will not load up if you don't go through the steps. thanks.
Apr 05, 2009 | Homelite Garden
Garden Logo
272 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
