Question about Fuji FinePix S602 Zoom Digital Camera
NiMh Battery life camera shuts off powers down with full batteries
The camera shuts down with fresh NiMh batteries installed.  Can't get more than 10 pics before it just shuts off.  Tried several different batteries, all rechargables and same result.  This camera didn't always do this.  Used to work for hours with no problem.
  • gotnvols Dec 02, 2007
    The camera shuts down with fresh NiMh batteries installed.  Can't get more than 4 pics before it just shuts off.  Tried several different batteries, all rechargables and same result.  This camera didn't always do this.  Used to work for hours with no problem.
  • 22 Answers
The battery cover shorting isssue is well known and can short a battery, but it would seem unlikely that it will deplete them that fast, as it takes about a day to do so with a fresh battery pack.
Instead, I would suggest you have a close look at your battery compartment contacts. NiMH batteries can leak when they get old, which can cause contact corrosion. Once you get corrosion the voltage can drop below the cutoff point and voilà, short battery life syndrome. Cleaning the contacts with an eraser or, if really bad, with some fine sandpaper should solve this problem.
If you don't use your camera a lot, remove the rechargeables at least once a month to recharge them and put them back in to keep the backup battery recharged. If they feel greasy they are leaking, discard them. NiMH batteries, whether used up a lot or not rarely last more than a few years.
HTH...
Posted on Sep 23, 2008
Hi this is a common problem for the s602z n is shorting on the battery cover. It is easly fixed. Search the net n there is a bloke here in Australia with the solution on his own fuji website.
http://www.digsys.com.au/S602/S602.html
Rgds
Paul
Posted on Nov 19, 2007
No. Better batteries help some.
Posted on Nov 15, 2007
Low battery display
go to your local walmart and but a set of nimh rechargeable batteries and let them charg when done charging install them in to you camra then hit the menu button go to the setup display and scrool down to the battery type and choose Ni-MH this will save you battery life from 5-15 min to 5-6 hrs of life.
May 06, 2008 | Samsung Digimax D53 Digital Camera
Batter Life
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
Kindly regards,
micro
Feb 28, 2008 | Samsung Digimax S630 Digital Camera
OBSCENELY short battery life in PowerShot A40 :-(
You need to use Nimh battery specifically designed for digital
camera use with high ampacity usage.
Jan 05, 2008 | Canon PowerShot A40 Digital Camera
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Choosing batteries
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Fuji FinePix S602 Zoom Digital Camera Logo
657 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
