Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
My glow bouy won't hold a charge.
My glow bouy pool light won't hold a charge, what's the fix? Glow buoy will not hold a charge, red flashing light. Called Company contact number and they said they no longer can provide service information--does anyone know what to do about getting new batteries?
  • 640 Answers
According to the owner's manual that I have for this swimming pool light (troubleshooting section), a blinking red light is definately a charging issue. The manual recommends that you unplug and replug in the light several times. If the flashing continues, they recommend that the batteries need to be replaced. Unfortunately, you cannot replace the batteries yourself. They specifically state that you cannot open the housing yourself. If you did, you would risk electrocuting yourself AND void any warranties that you have. You will have to take it into the retailer that you got it from or an autorized pool supply/repair shop or replace the whole light.
Posted on Jun 16, 2010
Changing colored lens on glow buoy
The way I change the colored lens to the glow buoy is with three standard screw driver, about a 3/16" head good 4" shank or longer. If you look close you can see four grab tabs in the middle of the lens, these hold on to a lip on the clear lens. Twist the colored lens till you can get to three of the tabs. I couldn't get to all four do to the triangular shape of the top. Slowly wedge the driversunder the lip of the colored lens center to the tabs one by one, alternately pressing the screw drivers deeper once you get the to where they wil continue no futher, due to the bevel in the lens, take the two drivers opposite each other and push them in forcing the edge outward. The lens will pop off violently, and most likely shoot the third screwdriver across the room, but after changing them a few times the lips wear down soon you will be able to pull them off with a good pair of fingenails. Hope this helps, you may scratch the lens a little, also the covers have a bit more flexibility then I thought I was afraid to break them but now I see the give.
Jul 20, 2013 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I need to purchase/order a new plug in device for the glow buoy
You might want to check with backyardcity.com. I know that they sell an assortment of swimming pool lights. If they don't carry the charger, they can probably direct you to the manufacturer. If you have a number to the manufacturer, you might want to contact them directly. Also, a local pool store might carry them.
Jun 27, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I have lost the ac charger power cable, manual, and other accessories that came with the 92000 i purchased a few years ago during a recent move. Where can I order these items and other accessory items for...
I am not sure if they sell accessories, but I know that Backyardcitypools.com sells these kinds of swimming pool lights so they might be able to help you get what you are looking for or point you in the right direction. Hope you find what you are looking for!
Jun 11, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Battery will not hold a charge. can i replace the battery
As far as I know, you cannot change the batteries on these swimming pool lights. If the rechargeable batteries are no longer holding a charge, you will probably have to replace the entire light.
Jun 04, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My Glow bouy does not hold a charge also have no idea where to get it fixed.
If it is failing to hold a charge, the rechargable batteries have probably worn out. As far as I know, you are not able to replace the batteries in this light. You can call backyardcitypools.com, which sold this particular light, and they might be able to tell you how to do it. If not, they can give you some options for replacing the swimming pool light.
Jul 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Glowbuoy flashes on and off after charging,hardly been used
If your swimming pool light is not holding a charge, it could be that your battery pack is defective. For this particular light, you cannot change the batteries yourself. It is designed so that the housing cannot be opened by the owner. You would need to take it to a pool professional and have them change your rechargeable batteries.
I need a new bulb for my glow buoy pool light! how much and were thanks!!!
The Glow Buoy swimming pool lights were designed so that the bulbs can only be replaced by a licensed pool supply store. If you open the light yourself, you will void any warrantly and risk breaking the unit. Becuase of this, they don't sell the exact bulbs that you need unless a pro is installing them.
Jul 07, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Glow bouy will ony stay on for 45 minutes
According to the owners manual for these swimming pool lights, if you light is not working for the full amount of time expected (at least 4 hours) you should try the following troubleshooting steps:
1. The battery pack might not be fully charged. Check the charge and recharge if necessary.
2. The battery pack or charge might be defective. Run the light through several charging cycles. If it fails to hold a charge but the indicator lights are showing normal operation, take the light to an authorized repair shop.
3. The battery pack might be old. After approx. 600 charges, the batteries might lose their ability to be charged. If this is the case, take the light to an autorized repair shop to receive new battery installation.
4. The product might be overheated. The light's internal temperature regluator will shut of the product to prevent damage. Allow the light to cool down and then test for normal opperation.
Jun 15, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
my glow bouy just keeps flashing on and off after recharge, had it about 2 years hardly been used
Apr 10, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
398 people viewed this question
Top NRS Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
