Question about Senco SNS41 16Ga Stapler 1" 2"
I have a stenco sns 41 stapler that double fires and then jams.
Also, is there place where I can get a manual for this stapler?
  • 4 Answers
Make sure your air is regulated down to the right pressure ( usually 80lbs. ) also there is a way to staple without double firing and that is to hold finger on trigger and tap gun like a hammer but a lot lighter.You can also adjust the safety on the nose of the gun. I believe there is a screw on the front side to loosen and adjust the safety. As far as the manual, just go on their website and get on to download, because they are free always.
Posted on May 27, 2009
How do I free up a jammed staple in an Arrow P22 model?
Hi Francis. Remove the staples from the Arrow P22. Place a piece of wood (rod) about a quarter of an inch thick between the arms of the stapler just behind where the stapler is ejected and press down a couple of times until the jammed staple is dislodged. If the plunger is already jammed in the downward position then first pull it up and then push it down again. This procedure has worked for me on a variety of staplers over a period of very many years. Good luck!!
Feb 04, 2015 | Arrow Plier-Type Stapler - P22
When I push the button it will not open to let me add staples
Hello, Go to this website for support phone numbers and a place to download operator/trouble shooting manuals. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Apr 25, 2014 | Stanley Bostitch 02210 Electric Stapler...
The problem i'm having is with a senco sn 41 stapler the driver wont fully return to the top
Hello try to put some oil in the connection of top and bottom may be this might help. please rate my comment
Nov 21, 2011 | Tools & Hardware - Others
Sns 41 as soon as i connect air hose, driver goes down and air comes out exhaust
May need cylinder seal # bc0438. When this seal fits loose or is cracked, air will leak past and push piston down to bottom of the cylinder. If the seal fits snuggly and looks in good order, suspect headvalve orings and cylinder spacer orings leaking. Order oring kit and seal. Use silicone paste lube on all the orings. Look carefully at the surfaces where orings make contact and remove scratches with 300 grit sandpaper(fine scratches will allow air to leak past new orings). To make the gun work with poor fitting orings. Clean inside of gun with diesel and apply plenty of silicone paste to orings (using same orings if not cut or broken). If gun works as normal, the silicone paste is temporarly sealing the orings. It may continue to work for a while untill you get new parts. Good luck with repair.
Aug 13, 2011 | Senco SNS41 16Ga Stapler 1" 2"
An office dummy put regular staples in the Swingline 660HD stapler which is now jammed. I can't figure out how to open the stapler to get access to the staple tray. I can't pull them out with a large...
There's a rectangular opening at the front end of the stapler. You can insert a rod that fits in the opening, and push the staples back out if they're not hopelessly jammed in-place.
Feb 04, 2011 | Office Equipment & Supplies
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Electric stapler won't staple; Panasonic as300 will fire but no staples come out and I do not see any jammed staples when I open the cassette.
On the side of the stapler are the instructions - no joke - stick a flathead at the lip of the metal striker and push the flat head up - while pushing the realse at the back - use A LOT of force - that is how ours popped open. It was jammed in the back with several staples that were not visible as a jamb in the front where the staples come out. the whole magazine will pop out when it is freed.
Sep 13, 2009 | Office Equipment & Supplies
Double or triple firing
Great, Sami! Could you please rate my assistance. Thank you.
Charlie
Aug 19, 2009 | Electric Stanley Tre500 Staple Gun /...
Senco staple fastener not firing.
Make sure you actually removed the entire broken staple and there's not a piece still wedged up in there somehow.
Try raising the air pressure up to 125 psi and plug it in and unplug it a few times. Sometimes the piston can get jammed, and a smack with the palm of your hand on the side of the cylinder will jar it loose. If that doesn't work, try pulling the trigger as you jam the nose of the gun against a soft piece of 2x4 or something, repeatedly firing and jarring the tool. If this doesn't do it, you may have to open it up to clear the jam and put it back together.
Mar 28, 2009 | Senco Fastening Systems 760102N Pro 25 Xp...
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Senco SNS41 16Ga Stapler 1" 2" Logo
234 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
