Question about Sharp AR-5316 Advanced Digital Imager Copier
How to put developer(black) into copier how to enter thes functions please... i must enter in expert mode before entering codes...
    President:
  • Sharp Master
  • 990 Answers
Hello sir; This model copier, the developer come with toner cartridge, you don't have developer replacement problem.
Posted on May 26, 2009
How to enter f8 function in konica minolta ineo250
Utility/counter, details, stop 00 stop 01, function F8 was developer replaced before you do this WAS THE DEVELOPER COUNTER RESET before you put the new developer in. The machine runs on the counters if you did not reset the machine will think the developer is old when in fact it is new and will cause image issues and codes
Nov 01, 2015 | Konica Minolta Office Equipment & Supplies
Pls . help me experts , i have kyocera km3050 copier but the lcd touchscreen is not responding but days past when it still responding its getting hard to respond. please help me with this experts
A hard reset can clear minor error codes. A lot of times you do not really need to call for your support contractor. Sometimes errors stop the function of a machine, but the machine could still function properly with a hard reset. Perhaps there is a better description than hard reset, as "reset disable function" is a little bit confusing and not a phrase you were likely look for.
Contact your service provider before following these instructions.
Use at your own risk. Perhaps there is a possibility of causing damage. Again, contact your provider.
From our copier service company:
This reset is used for two purposes:
1) reset any data that may be "hung up" in the hard drive.
2) reset an error code and attempt to continue use. (If the error recurs, then you should escalate to whomever supports the copier.
Hard Reset Procedure:
Press Status button
Enter 10871087 - You are now in Maintenance Mode
Enter 906 (do not enter any other numbers!)
Press Start
Press Execute
Press Start
Copier tells you to turn it off/on
Turn off power by switch on right side of copier (hard power off)
Turn on power by switch on right
I have seen to use code 163 instead of 906. I don't know what this does. Again, consult experts before using this code or any others.
Feb 03, 2015 | Kyocera Mita KM3050 Black Toner Cartridge...
How do i fix the error code c2557?
in utility you have somthing like "check counter" try to get inside and then stop00stop01
Jan 20, 2015 | Konica Minolta Bizhub 222 Black and White...
How do you reset drum and developer counters
Press the Utility/Counter button then meter count then details then stop 00 stop01 to access service mode then clear drum and developer do not exit out all the way once counters are cleared touch end then power off the main PWR ON/OFF switch located on the left hand side of the machine in the rear then remove the Drum Cart and replace drum and Developer then reinstall drum cart. Enter service mode again Run Function F-8. Do no print or copy before doing this. So disconnect FAX line and Network cable.
Apr 08, 2014 | Minolta bizhub 350 Black and White Copier
Bizhub 750, i put new developer, is there any setting that i have to do after this job?thx
After you change the developer enter in service mode press Utility key- Meter count- Details-Stop-0-0-Stop-0 -1press Counter select Special(optional)parts counter select Developer and reset the Developer counter value by pressing C.After reset the developer counter enter in Imaging Process adjustment mode select Drum pecularity mode and select Cartridge installation mode press the Star button.The process duration is 2-4 minutes.Whwn thw ok appears press Exit and return the copy mode,make a test page.
Mar 24, 2014 | Konica Minolta Dv710 O2xk Black Developer...
How can I enter service mode in panasonic workio dp 2330 to set new developer. Pls advise
To enter service mode press FUNCTION, ORIGINAL SIZE (LEDGER/A3) and 3 keys simultaneously then F1 will appear. Press 8 on key pad and F8 will appear, press start, select 09 then ok or start and this will run developer for a few minutes. when done press FUNCTION and C (CLEAR) keys to exit service mode.
Jul 17, 2011 | Panasonic Office Equipment & Supplies
Hi, i need change number of ring to fax into panasonic 8020e
yep. you can only change it through fax service mode. here check it out:
To enter the Fax Service Mode
  • Press “FAX/EMAIL” key.
  • Press “FUNCTION”, and then “7” keys.
  • Press “MONITOR” four times, then press “*”.
  • Enter the desired code number, or press the “V”, ”/\” arrow keys.
  • Go to function parameter setting, and then press START key
  • Press '4' and then '5' keys or press 'V' to select #045 mode.
  • Enter a number (1 for 1 ring, 2 for two rings...), and then press START key to save.
  • To exit the Fax Service Mode press “STOP” key.
Jan 11, 2010 | Panasonic DP-8020E Black and White Copier
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Error code e020 04e0 came up
Enter in service mode FUNCTION > INSTALL > INIT_K
Jul 02, 2009 | Canon CLC 1150 Color Copier
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Sharp AR-5316 Advanced Digital Imager Copier Logo
131 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
