Question about Westinghouse TX-42F430S Television
Westinghouse TX42F430S how can i find a list of what channels are with new tv hook up i have never seen a channel be a decimal. i just want to know what im watching
Channels with a decimal are digital. You are probally getting the through the air. Currently mine are all the digital versions of the normal channel. Ie: 5.1 digita version of channel 5. Your's maybe different but if there over air it is probally a local station in digital and you should be happy.
Posted on Dec 23, 2007
How do i add a channel to a westing house tv?
Simply contact their support at the following link: http://westinghouse.com/contact-us/ but know what your model number is (not the serial number).
I think you are not allowing the scanner to actually find the channel before switching out of the menu. I can think of no other explanation for both manual and auto functions to fail (unless you have a lemon).
If you do not have a manual, you can try one of the alternatives below.
Or, you could try to google for the manual for your particular model of Westinghouse TV and find the procedure there. Below I simply list a couple of manuals that may be applicable but clearly are for two models of Westinghouse TVs.
Manuals Online offers a simple to understand procedure (if you can download the manual, I have trouble reading it in my browser for some reason). The information is on page 43 of this alternative. http://tv.manualsonline.com/manuals/mfg/westinghouse/ld265.html?p=43
It has diagrams of the menu.
Pages 35-38 of another manual covers both automatic inclusion and manual addition of channels on a particular Westinghouse TV. http://westinghouseelectronics.com/wp-content/uploads/2010/05/LD-4258-User-Manual.pdf
Feb 06, 2015 | Westinghouse Televison & Video
I have a Samsung hdtv but its not playing in hd.I have it hooked up to cable straight from the wall bypassing the cablebox.Is it the tv or cable?
You do not indicate if you have auto programmed the television to get digital channels, If you are selecting a channel without a decimal point, for instance 82.3 is NBC hd in my cable system. If your cable provider does not produce these on direct cable then you can not get HD without a box.
Try to Auto Program your tv in the cable mode STD format, this can take up to 20 minutes to complete scan including deleting scrambled channels. After programming try the lowest or highest analog channel like 2 or 70, channel down or up from there to see if any digital channels appear.
Mar 01, 2013 | Samsung Televison & Video
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
We have an antenna. Can't get Ch 3 on this tv to use our vcr/cd.
If you did a channel scan to build the channel list, the up/down channel will never bring you to 03, but you should be able to manually add the channel through the on screen menu system.
Alternately, simply punching in 03 (or 003) on the remote should force the TV to tune in channel 3.
Be sure the vcr is tuned to channel 3 as well, some are 3/4 switchable and default to channel 4 not 3.
A last resort if you can't get any of those to work is to get a cable splitter and run it in reverse with the 2 ended side going to the antenna and vcr and the single side going to the TV and doing another channel scan while the vcr is playing.
If none of these work, I'd need to know more about exactly how everything is hooked up.
ie - if the VCR is hooked into the component input on the TV, you need to switch the TV to A/V or composite or component rather than channel 3 etc. etc.
Mar 18, 2011 | Westinghouse SK-32H240S Television
I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
Aug 28, 2009 | Westinghouse SK-42H240S Television
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
MagnaVOX
The channels without the decimal are analog(old). The channels with the decimal are digital(new). After february 2009 they will all be digital with the decimal.
Oct 07, 2008 | Televison & Video
Westinghouse LTV-19W6 TV Won't change channels
An email from Westinghouse that fixed the problem for me.
Thank you for your inquiry.
We apologize for any inconvenience in waiting for our response, but below is what I can suggest to move forward.
It appears all you need to do is run a channel scan on the unit. Once you have run a channel scan, you will be able to scroll through the channels using the channel up and down buttons.
If you have any further questions, you may contact us through email, or by calling us toll-free at 1-866-287-5555, between 9am and 9pm Eastern Standard Time, Monday through Saturday. One of our technicians will
assist you.
Aug 05, 2008 | Westinghouse LTV-19w6 Television
Televison & Video Logo
182 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
