Question about Homelite Mighty Lite Lawn Trimmer
Homelite trimmer dies every time I squeeze the handle
It will run until I squeeze the handle to use it. Same problem KenniBoy posted. Every time I squeeze the trigger, the engine slowly dies.
  • brockolious May 26, 2009
    Thanks very much Wolverine.  I suspect it's improperly mixed fuel and oil.  I flushed the fuel tank and let it sit overnight to reduce condensation buildup.
  • 15 Answers
This can also be (just did this too with my Zip Start):
1. Nasty Carb (loose screws or just funky)
2. Leaks (be they Air or Fuel Gaskets!)
3. Funky Exhaust Port
4. Fuel (check it ALL, lines, filter, tank)
5. Fuel CAP (believe it or not, they ARE vented for a reason, to PREVENT Vapor Lock)
6. The Spark Plug (if it is weak, she will act like that on the High Side, sometimes, even when Idling nicely! Double check your Plug Seat as well, where the Plug meets the Cylinder Head, if it is funky bad, clean it up, a good ground is a must!)
Remember that on a 2-Stroke, Spark Plugs take a hell of a beating on heat, or getting over-fueled (which they do, when carbs are unmaintained). And UNLIKE 4-Strokes....they have to burn OIL too! (Foul faster)
Fuel -> Fuel Filter-> Fuel Line-> Carb->
Splits here into TWO paths:
1. Fuel Bulb-> Fuel Line (Return Line)-> Fuel Tank
2. Fuel Bulb-> Carb-> Intake Port-> Piston-> Exhaust Port-> Exhaust Port Screen
Electrical:
Magneto-> Rotor Magnets (for Spark Plug, AKA- Ignition)->Spark Plug Wire->Spark Plug->Cylinder Head
Kill Switch (grounds all the above to the cylinder)
Running: (Carb, etc.)
Throttle Cable (super simple)
Carb Butterflies
Carb Seats, Carb Gaskets (air leaks/fuel leaks)
Needle Seat (Fuel Flow, Gummed UP!)
Any and ALL Fuel/Air Ports in the Carb.
Fixes: CLEAN THE CARB. I don't mean spray some WD-40 on it and call it "clean". Tear it ALL the way down (CAREFULLY!), and put her back together. Use some compressed air and Gum-Out.
NOTE: "Gasket Kits" are NOT a fix EXCEPT for leaky GASKETS!
They do NOT fix 99% of the problems: Spark Plug or Dirty Carb!
They will NOT fix "Operator Error" either!
NOTE: If it requires fuel (or a mix), it will invariably get gummed up, and nasty. Carbs are about the #1 reason ANY small engine fails, and ONLY second to people who will....not....maintain...equipment.
("Operator Error")
NOTE on Carbs: If it worked brand new without an adjusted carb (factory settings), it does NOT need adjusted now. What it needs to be is CLEANED, and put back into service. E.G.- MAINTAINED!
Posted on May 28, 2009
  • 420 Answers
The engine is not getting enough fuel to the high speed jet. The issue may be one of the following:
  1. Restricted fuel filter (in the fuel tank)
  2. Pin hole in the fuel line (are bubbles seen traveling in the fuel line?).
  3. Improperly mixed fuel/oil
  4. Poor grade oil ~ never use outboard or genaric 2 cycle oil, use the manufactures oil or gold spectra (available at motorcycle shops).
  5. Mal-adjusted carburetor, if you changed the brand oil you used in the past the carburetor may need to be readjusted to compensate, or switch back to the oil used before the issue occured.
Posted on May 26, 2009
After checking the plug (absolutely clean!), and the carb function, and the air filter media several times, I finally noticed two buttons on the inside of the air fliter housing, and discovered they were NOT aprt of the plastic housing, but rather were built-up dirt, mixed with oil, right at the air intake! I cleaned them off, and now it runs like new (even with old gas)! So it turns out it was starved for air, not fuel. Often the simple fix is staring you in the face, and you don't see it because you're looking for sonething more complex. Thanks for the other opinions.
Posted on Apr 30, 2010
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
After cleaning carb, engine will start and run fine until it starts to idle then dies or you let off the throttle and dies....have to hold throttle open to start !!
Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
I know you've cleaned the carburetor, but pay attention to some of my details that you may have missed. They are crucial to getting your machine running properly.
These Tips should do it for ya.
Good Luck!
Jim
Aug 09, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite Easyreach Model # UT20044A that will start, but then dies. Cleaned the filter, spark plug but still dies
Check that the carburettor and fuel lines are clean. If the unit has not been used for a while the gas (petrol) will evaporate leaving the oil behind to choke up the fuel system. Dirty fuel will do the same. When adding fuel use a funnel with gauze filter in it and always empty the fuel tank and then run the motor until it dies when you've finished work.
Sep 09, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
SX-135 Homelite trimmer-carb diaphram cracked
You can go to an outdoor power & equipment type of store (Independent store). The cost is around $12-$18.
Jim
Jun 19, 2009 | Homelite Mighty Lite Lawn Trimmer
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,216 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
