Question about Toshiba TLP 671 Multimedia Projector
How to reset lamp timer for a TLP 671
It lights up then after a few minutes it goes off. red lights go on. the fans are working and the fan screen is clean can you tell me how to reset lamp timer for a TLP 671
  • 105 Answers
Hi there folow the link bellow for the manual
Regards Al "alstech"
http://www.fixya.com/support/p147512-toshiba_tlp_671_multimedia_projector/manual-15037
Posted on May 26, 2009
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
I have a Toshiba TLP 260 Multimedia Projector --after a couple of minutes of being on the fan icon appears in upper left corner the projector will shut down indicator lights for the fan and on, goes red. ...
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Apr 21, 2010 | Toshiba TLP 260 Multimedia Projector
Hi I am Vortash sounds to me like a ballast or bulb fault this could be one of those silly faults you sometimes get .. the unit thinks the bulb has gone .. why because it goes out the processor is told this and the machine acts accordingly . Now I have had where the plug that is in the bulb housing is at fault the connectors expand under heat part and the bulb dies also had the same where the fittings on the end of the bulb wires are not secure and the same happens .. Also it could be a more serious Ballast failure or simply dry joints around the ballast unit ... without looking for myself I couldn't be sure but this is where I would start .. hope this is of help Regards Vortash
May 17, 2009 | Toshiba TLP 671 Multimedia Projector
My TLP680U projector shuts off after 1o minutes of operation.
toshiba is not one of the most rliable makes im afraidi have seen this fault before and it turned out to be the bulb which i had recentley replaced and this was apparentley the wrong one and gave the same sort of results.
Feb 25, 2009 | Toshiba TLP 680 Multimedia Projector
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Unit turning off after displaying red pc chip icon
Hi whitiezn
If you say that this unit is very new , it should on all accounts still be under warranty.
Contact your local Toshiba Service Centre and have this problem sorted out on their account - the machine should still be under warranty.
May 05, 2008 | Toshiba TLP-ET1 Multimedia Projector
I NEED SOLUTION
Hi, Pls check the small Fuse for the supply of the fan. Or you can send it to us to repair.
May 26, 2007 | Toshiba TLP T50MU Multimedia Projector
Toshiba TLP 671 Multimedia Projector Logo
636 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
