Question about RCA D52W19 52" Rear Projection Television
Blown cap where can i find CL031 CAP .0087MF 200Vdc this capacitor is located directly above the flyback next to the opening of the heatsink
  • jaredbeau Oct 22, 2007
    correction 2000Vdc
I ordered mine from (Union Electric Distributors, Beecher, IL), part 259321, $2.59 each.
Posted on Jan 06, 2008
Spraying sound and tv shuts off
the flyback transformer or the Box cap CL031 is arching and will need replacement the flyback is most likley of the two. You can get flyback transformer with instructions from
Jan 18, 2012 | RCA HD52W59 HDTV Projection Television
Im working on a RCA ITC222-it has 3 chirp problem with burnt CL031. Unfortunately RL106 is burnt (I need value)and, FL100 is open (I need current rating)and finally, DL032 and DL033 are shorted (I need...
Cl031 is the sfaety retrace capacitor check DL030 an the HOT trans they are most likley blown as well. Usually if anything other than the Hot and DL030 are blown the entire deflection board will need replacement. Its also best to check all three of the CRT necks to be sure none are cracked and broken on the CRT necks . Unfortunately several designs of the deflection components had different parts although the deflection boards will usually interchnage bewteen the ITC222 chassis sets. The ITC222A will not interchange. has replacement parts and boards and can also assist with part numbers that you require.
Oct 14, 2011 | RCA HD52W59 HDTV Projection Television
I have replaced the flyback, all the bulging caps, a burnt rectangular cap and the HOT and still nothing
If the set had a burnt CL031 Capacitor and its now squealing you may have a broken CRT if not the deflection board itself will need replacement. But I would inspect each CRT neck real good even loosen the yoke as often they will crack right at the yokes clamp line.
May 04, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Picture and sound disappeared audio flashed on and off ,picture got small, and changed colors then electrical burn smell
Check the retrace capacitor it may have burned a hole through the Circuit board ( CL031) located in front of the flyback ( Grey Rectangle)
Nov 09, 2010 | RCA Televison & Video
the flyback or CL031 are the usual causes with that chassis doing that. Usually CL031 will burn a hole through the deflection board its located about two inches in front of the Flyback transformer.
Mar 15, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Convergence Issue for RCA R52WH76...
Please check the fuse again. Do not just pop the cap off and visually inspect it. Even if the filament appears to be intact, it's probably not. Like ctf1800 said, it's the fuse.
You need to test the fuse for continuity.
The problem that you explained is due to the blown fuse. There are no convergence IC's in this set. I'm am 99.9% certain your fuse has blown.
Get the fuse here:
After you install the fuse, you MUST resolder the points at the flyback transformer which is located next to the fuse (red wires leading to it). Cracked & cold solder usually develops and will cause FL231 to fail again if you skip this step.
Oct 30, 2009 | RCA R52WH76 Television
3 blinking lights after replacing CP150, CP110, Flyback, CL031, and (2) 10 Watt 1.5ohm 5% resisters.
Your right on these sets you have to replace all 3 capacitors 2200uf 16v and two 220uf 35v.
Aug 30, 2008 | RCA D52W19 52" Rear Projection Television
Go into menu look on setup see if convergence comes up then do auto converg. if you do not see convergence on menu then you have an open fuse FL231 square brown cap next to flyback.
Jul 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
418 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
