Question about Sony Audio Players & Recorders
Sony tc-we471 deck belts are melted or broken need to replace
Need all belts for sony tc-we471 need size
    Problem Solver:
  • 18 Answers
Well I can't find this model exactly but other sony dual decks seem to use a belt that is 8.2 inches in circumference. See page 88 of
http://russellind.com/client/download/PRB_Belt_XRef.pdf
you will have to match the width as close as what you have left.
or try to call Sony service
Posted on May 31, 2009
The rubber belts on my sony cassette deck(TC-W380) are worn out and i need replacements.Does anyone know where i can purchase them?
Ive used o-rings from home depot with no issues before....I did a little research and the part numbers match to
http://www.ebay.com/itm/SONY-TC-WR665-WR670-WR690-WR701ES-Double-Cassette-Belt-Kit-GTD-5-YEARS-/140828351357?pt=US_Home_Audio_Cassette_Decks&hash=item20ca061b7d
I would investigate on your own to make sure, but the parts cross referenced
Aug 20, 2012 | Sony Dual-Deck Cassette Player/Recorder...
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Sony Stereo Cassette Deck TC-V7 Will not play suspect drive belt stretched or broken Want exploded view before dismantle or to check if a part is available.
take the cover off and see where the belt is, it should be selfevidedt how it is replaced, a plate may have to be removed from the mechanism
Mar 30, 2009 | Audio Players & Recorders
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
605 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
