Question about ASTVision 7L 17 in.CRT Conventional Monitor
S-video Using s-video for a second monitor. It's all set up, but that screen is always blank. What am I doing wrong. I even hooked up my dvd player to the s-video on that monitor and it shows nothing. The analog works fine.
0 characters
1 Points
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Monitor comes on shows a screen and then the power buttom begins to blink every 2 seconds and a black screen on the monitor remains blank
Try starting your computer in safe mode ( tap F8 while it boots up). If this works then you have probably got it set to the wrong resolution. Set it to the correct resolution (google the name of your monitor to find it's maximum resolution, or just set it to something low like 800x600 or 1024x768) by right-clicking on an empty bit of desktop and selecting the video settings or control panel for your video card.
If this does not work and you have checked your cables and your video card, then I would suggest you have a faulty monitor.
Feb 05, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
DVDs do not play on LCD monitor
If you see the dvd on the laptop and not the monitor:
Your problem is probably with your video card and its settings and not the monitor.
Some video cards wont support dvd playback on two screens at once.
What you have to try is to enable only the external monitor and disable the laptop lcd.
This can be done using shortcut keys on the laptop (usually this involves using the Fn key and one of the F# keys at the same time- the F# key may have a picture of two screens on it or be labeled CRT-LCD)
You can also change the settings in the display properties settings.
Sometimes the display settings as far as resolution are set too high for some dvd players. Lowering the resolution can take care of that problem.
Jul 18, 2009 | Xerox XA7-192i 19" LCD Monitor
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
May 25, 2008 | Computer Monitors
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
Screens works for 5 mins then goes blank!!!!!
It could also be that the video card is not compatible with this monitor. After the pc boots up, can you get into windows? Does the monitor always go out at a specific time on boot? Say for example; you boot the pc, windows startup splash screen comes on; screen does a quick flash and goes blank. Then it maybe the BIOS setting for the video. Try changing the IRQ setting. You could also try putting the video card in another slot. Do you have the manual for the motherboard? Ray
Jun 20, 2007 | Relisys TL565 15" LCD Monitor
ASTVision 7L 17 in.CRT Conventional Monitor Logo
Top AST Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you an AST Computer Monitor Expert? Answer questions, earn points and help others
