Question about Sanyo DP37647 37 in. LCD TV
When I turn my Sanyo DP37647 TV on the green light comes on but there is no picture or sound.
  • zbeanster May 26, 2009
    I've turned it off and on and unplugged the cords. Do you mean it it my wall outlet that is bad?
  • CoppellTVRepair.com Aug 31, 2012
    While always possible this is sooo definitely not the common cause of the problem in those TVs!
    President:
  • Sanyo Master
  • 749 Answers
When there is neither picture nor sound you're likely in need of a service or replacement of the main board.
Service is usually the way to go as replacement is unable to find or too darn expensive, at least in the past year or so.
The typical indication of this problm is that the front light doesn't just stay green, but actually blinks for a second every 15-20 seconds.
If it does that you're definitely in for service.
See more at
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
The DP37647 model isn't listed there as we're planning to post about it in a separate article...however it has the same symptoms as some of the others.
If you want to send the board in for repair , shipping instructions can be found at http://www.coppelltvrepair.com .
It really isn't a simple DIY service like a fuse or capacitor replacement.
Posted on Aug 04, 2012
When I turn my Sanyo DP37647 TV on the green light comes on but there is only sound.
Posted on Oct 28, 2009
  • 822 Answers
Your power supply have problem thats why cannot power on.
Posted on May 26, 2009
He is correct. Its your power supply. Very common, yet expensive problem.
Posted on Sep 27, 2009
Black screen sound no picture
Check and replace the damaged component/s at its back-light inverter section circuit, or replace the back-light inverter board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 31, 2014 | Sanyo DP37647 37 in. LCD TV
How do i turn the sound on my sanyo dp37647 off
As nearly as I can determine from your description, you want to turn off the Sanyo TV speakers and direct its audio to the soundbar. Your initial setup procedure should provide an option for doing this. If not, there may be an audio control button on your Sanyo remote that will accomplish this.
Nov 30, 2013 | Sanyo Dp37647 37" 720p Hdtv High Def Lcd...
Sound but no picture
You could have a back light problem, or a video feed problem. I would suggest turning on the set and shine a bright light on the screen. Do you see faint video?
Nov 24, 2012 | Sanyo DP37647 37 in. LCD TV
Sanyo dp37819 i turn it on green light comes on but no picture or sound and green light goes on and off
You can send your main board to us and we can give it a try.
If it the front LED turns on for a while, then off for 1-2 seconds and then back on...we'll probably be able to help.
See http://www.coppelltvrepair.com for details and shipping instructions.
Jan 14, 2012 | Sanyo DP37647 37 in. LCD TV
My sanyo vison tv little green light comes on but no picture or sound. have tried turning sound all the way up and hitting the imput button to see if i can sound on anything but cant see the picture so not...
Its either a bad power board or it could also be the main, but power supply boards are common failure on older sets, you could remove the back and see if you see bad capacitors and replace them instead of replacing the entire board for a couple bucks if your tech savvy.
Nov 22, 2017 | Sanyo DP37647 37 in. LCD TV
I have a two wide line at the top and bottom of my tv picture. how do i get rid of lt? modle number dp37647-e-mail louisdyersr@yahoo.com
Sounds like you just need to change your display mode, look on the remote for a button that says zoom, also in your display menu with your remote, there also should be a setting that allows you to switch from standard widescreen etc. choose full screed or wide screen mode that should get you back to full screen, please keep me posted I would be glad to Trouble shoot this issue until resolved.
Jun 11, 2011 | Sanyo DP37647 37 in. LCD TV
My tv broke
if you have comcast you can use your remote to change the setting to DVD and then change it back to cable. your picture should then come back
Apr 24, 2010 | Sanyo DP37647 37 in. LCD TV
I have great sound on my tv but there is no picture
i had the same problem take the back off an unplug the lcd an give it a blow put bit all back together an fany's your ant
Sanyo DP42746.Can't get tv to come on. The green power LED is on.
unplug the power connector to the tv, wait two minutes then plug it back in and try to turn on the set... this worked for me.
Dec 20, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP37647 32' lcd hdtv
it should you my need the original remote
Apr 05, 2008 | Sanyo DS32830H 32" TV
Sanyo DP37647 37 in. LCD TV Logo
2,541 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
