Question about Lexmark Color JetPrinter 5700 InkJet
I put a new ink cartrige and printer prints low coulour tone.
Doen`t show that colour ink (lexmark 80) is down put prints low colour tone. Black is fine... Help! email please
Reseat your ink cartridges and alos clean them, also clen the bar.
Posted on May 27, 2009
  • Lexmark Master
  • 684 Answers
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
My Lexmark printer 1270 only prints in black and white although the colour cartriges have good ink levals. This has just started happening, it was happily printing in colour not long ago. Many thanks.
Jast go to print option. Then Mantainance. Then try to print a nozzale. If all the colour comes out properly ( with out dot or misline), your cartrige head is goog for print. If not, your printer cartrige head is block. To reque from the problem follow the proces:
1. Unpluge colour cartrige.
2. Try to clean the cartrige head with soft cloth and amonia gentaly.
3. Try to out the ink through the head nozzale pore by using shaking or gentaly swape by soft tissue.
4. Now put the cratrige head upon a soft tissue. ( ink will comes out). If not, repit stage 1-4 until ink come out.
Thank you
Jun 07, 2011 | Lexmark X1270 All-In-One InkJet Printer
I have inserted both my blacl & colour cartriges properly but still my printer is showing some problem with my black cartrige
When ink cartridges get low they can dry out if you do not print that frequently. So try a new cartridge. Make sure that the carriage is clean, wipe down the copper contacts on the carriage under the black cartridge with alcohol. Also ensure that the cartridges themselves are not all coated in ink.
Dec 03, 2009 | Office Equipment & Supplies
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Any colour print is flooded with blue ink
Sounds like a bad cartridge and it will be about empty by now anyway.
You can clean the contacts on the cartrdge gently with a pencil eraser.
If it does this with a new cartridge you should uninstall and reload your device with the latest drivers from the website.
Lexmark is notorious for poor driver support.
Good luck! Jidza
Jan 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
C4200 printer stop printing in colour
check the printer property if the colour ink is mark also check the ink level if you still have ink in the cartrige. to go to the printer property click on start menu locate printer and fax click on it when open move mouse on your printer name and right click on it scrown down to property that it the last task then click on the general task click "printing references" when another task open click on the advanced. There you can find the black and white or colour you can then select which task you want to do in some clolour printer task promt automatically which you can select the task you want to perform but in other printer you have to go to the printer property to specified which task you want to do. if you have low ink level then you have to change your cartrige to new refilled ink.
Nov 17, 2008 | HP Office Equipment & Supplies
My printer, a Lexmark 1300 series USB printer, will not print in black ink. It has plenty. The ink is proper lexmark ink. It just appears to not be looking at it's black ink cartridge at all as when I put...
Check your printer preferences and be sure that you're printing in the right way. Select grayscale and see what's happen.
Delete all printer pending jobs.
Take out the cartridge, turn off the printer and wait 5 min.
Turn on the printer, insert the cartridge and try again.
If nothing happens, replace the cartridge
You will find more info here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Oct 09, 2008 | Lexmark Office Equipment & Supplies
Photosmart 3300 will not print black ink new cartrige. Self test failed,prints colours OK. page count 2698 Began problem perfect print top of page,fainter and blured as printed down page, replaced...
Take a dish- put damp tissue in it- if it can a one of the alchohol based cleaning tissue fine.
Stand the cart init for 10 minutes.
with a similar tissue give the contact sheet a wipe. and if it is flush to the bodty see if it has some give.
Reinstall and try
Jul 16, 2008 | HP Office Equipment & Supplies
Lexmark Color JetPrinter 5700 InkJet Logo
123 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
