Question about GE Refrigerators
Ice forming on top of items on freezer
GE Profile 24 fridge making ice on top of items in freezer.
  • khaophadt May 26, 2009
    Model TFX28PPBG WW
  • GE Master
  • 4,654 Answers
Sounds like your refrigerator is not defrosting. Could you look for the model number in the places listed in photo below and I will help solve the problem. Sea Breeze
Posted on May 26, 2009
  • John Tripp
    John Tripp May 26, 2009
    Inside the fresh food compartment and behind the control panel is a defrost timer. Sometimes there is a small opening through the panel and a plastic plug covering the hole. Remove the plug and slowly turn the timer until the compressor stops. Leave it there until the compressor restarts about 20 to 30 minutes later. If it does not restart then we know the timer will need replaced. The part number for the timer is WR9X489 Use care when your refrigerator is plugged in!
    Click on link below and enter your model number. You will seed many numbers like yours but it really does not matte, they are basically the same. If for some reason this does not solve the defrost problem then we will need to look into the back of the freezer compartment and check the defrost element and defrost thermostat. Thanks, Sea Breeze
    http://servicepartstec.blogspot.com/
Back wall ice buildup, fridge not cooling but freezer is fine other than ice. Back wall of refrigerator squishes with sound of water behind it. Have had it unplugged for 24 hours, ice gone.
Anytime you have ice buildup in back of freezer it indicates that the auto defrost mechanism is not working. Check the defrost timer, heater element, defrost thermostat for proper operation.
Jul 19, 2015 | GE Profile 24.7 cu. ft. Top Freezer...
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
