Question about Craftsman Garden
Engine not getting gas.
I have a Sears 24HP Lawn & Garden Tractor about 10 years old w/about 510 hours on engine which is a Kohler V Twin. It has not been used for about 1 year. We have checked all fittings and connections, added new gas and oil and recharged the battery, it still will not start....any suggestions? We need HELP
  • 404 Answers
If the fuel is getting past the fuel filter the issue could be a stuck needle valve in the carburetor. If the carburetor has a drain button on the bottom of the float bowl push it to ensure fuel flows freely for several seconds, if there is no drain plug or button pinch shut and disconnect the fuel line from the inlet to the carburetor, direct the line into a clean container and remove the pinch clamp, if fuel flows freely the filter is not clogged, if the fuel does not flow well replace the fuel filter.
To unstick a needle valve use a short blast of low pressure air (5-7 psi) into the carburetor fuel inlet, if the needle valve is stuck the air will tend to all blow back, once the valve opens you will here a change in tone. If you do not have access to adjustable compressed air try tapping the side of the carburetor gently, if it remains stuck you will have to remove the float bowl to gain access to the float and needle valve.
Posted on May 26, 2009
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
My deck broke where the backet is welded to the deck its only 3 mnth old.
how old is the mower?most new mowers carrey a factorey 1 year warrenty and should be coverd.
Aug 21, 2013 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
Engine piston
SOUNDS like you have done a big end and when the oil gets warm the oil gets thinner and so doesent lub the engine so good and what you can hear is the piston either hitting the head or the bigend worn bearings on 1 cylinder banging on the crankshaft as they have to have oil there to lub and to pressure the bearings while running SO WHEN you get it rebuilt change your oil to a 20W40 in winter and 20W50 in summer and change it every 50 hrs for your own sake.
Oct 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Can you give me a ballpark figure on replacing a head gasket on a older Craftsman riding lawn mower...
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor won't start after only one summer's use.
Is it fresh gas? Gas deteriorates over time. If it is from last year your carborator is probably clogged with residue and needs to be rebuilt or replaced (if cheaper).
Apr 30, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
292 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
