Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Will not pump water into dishwasher what should i check?
What should i check.  I have no water coming in at all.
  • 234 Answers
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
It is usually blue in color with a couple of wires running to it.
It is usually right where your water line hooks up to the unit.
You can google dishwasher inlet valve and see a picture
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
Posted on May 29, 2009
Flashing clean and light wash light on my maytag MDB6650AWS
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html After the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Jul 05, 2012 | Dishwashers
My dishwasher want turn on
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Water won't drain and then dishwasher won't turn on
Jul 05, 2012 | De Dietrich 18 in. VZ9456 Built-In...
Can not start my dishwasher
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Thank You for using Fixya
http://www.espares.co.uk/search/dishwashers/p/1083
Jun 28, 2012 | Maytag Dishwasher
Dishwasher not working
Mar 12, 2012 | Kenmore Dishwashers
Kude70fxss check valve
After the wash the drain valve must be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Mar 11, 2012 | KitchenAid KUDE70FXSS Builtin Dishwasher
Water not coming out
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. After the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
To get an idea of how to remove and reset the filter and drain pump the following video will be useful.
Mar 11, 2012 | Frigidaire Dishwashers
My dishwasher won`t start. NO light are open. The electrical power it's ok.
Jan 27, 2012 | Blomberg DW 15140 Full Console Dishwasher...
VDB450 VIKING DISHWASHER BLINKS ONCE ON NORMAL AND ONCE ON ECONO WASH. IT SOUNDS LIKE IT COMES ON, BUT NOTHING HAPPENS AND NO WATER COMES INTO DISHWASHER. ALSO THE BLUE LIGHT AT THE BOTTOM IS NOT COMING...
Sep 29, 2011 | Viking VDB450 Dishwasher
Cycle starts but no water comes in.just gets hot and steamy
It can be due to a block in the inlet valve , a block in the pressure pump or the spraying arm. You need to check from the inlet to see the water flow into the unit. check also with a meter to see if the controller works to the cycle and there is output. If not the water within is heating and so there is steam . restoring the water flow will make the pressure pump to spray hot water. Check the pump and the spraying arm.
Sep 26, 2011 | GE 24 in. PDW7880JSS Built-in Dishwasher
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
224 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
