Question about Akai PT46DL10 46" HDTV-Ready Television
Replacement lamp cartridge Where to find one in canada if possible
Red light comes on when green is on .Called service # in manual ,and told to replace lamp cartridge . But did not give any info where to find them .Have been to 3 service depot ,but none have had any luck finding one.our set is only 2 years old .Was told by 1 serviceman thunderstorms cause problems with lamp ,but we have a surge protector bar . I will buy in U.S.A. if necessary
  • goosy Dec 05, 2007
    Poor picture quality and there is a crack across the (glass0 lamp
  • justbelly Feb 21, 2008
    I've been looking for a replacement lamp for about a month now. I ordered a lamp but it turned out to be the wrong one ($200 down the drain). the number on the casing 1-800-545-6254 has been changed 1014578#, I cannot get through. the web page it directs me too cannot be located. (JDS Uniphase Comp). I can't find the replacement lamp anywhere. I would hate to just throw this thing away it's less than 2 years old.
Lamp went out , know where i can find one
Posted on Oct 01, 2008
Posted on Feb 07, 2008
  • 3 Answers
You need to be sure you're purchasing the correct lamp. The AKAI's are tricking because some of the TVs used a 5kV lamp and some used a 15kV lamp...these are not interchangeable and it's probably what happened to you!
First thing I would do is be sure it's the lamp. You can use the lamp troubleshooting wizard here to diagnose it:
It may be a bad ballast or even a color wheel, but if it is the lamp, I would also suggest looking at how to replace the lamp on your own, as it's much cheaper than spending #300-$400 fom an AKAI distributor (which probably doesn't have it in stock).
For the replacement instructions, go here:
Hope that helps!
Posted on Jan 28, 2009
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
The red light is blinking and the tv want come on
First on this model remove the lamp and examine it to see if shattered inside---customer replaceable and door (unplug set first) is on left side as seen from the front.
With door off remove two brass screws and grasp handle on lamp cartridge and slide it out---with the screws removed the lamp cartridge just slides out--pull it out and look.
Mar 24, 2012 | Toshiba Televison & Video
My panasonic has a softball size red spot on it, and the lamp light indicator is blinking. how can I fix this myself
It is software, ans is replaced for free even if it is out of warrantee.
Don't rush to replace the lamp, it is probably OK.
Got the same problem with same TV (PT-61-LCX65) that was bought 4 years go in 2006 - first red spot appeared, then few weeks ago got green one nearby. Fixed it for free.
I called Panasonic using the phone number in the manual (1-888-843-9788), selected Service, told that I got the problem which is most probably "a manufacturer's defect" that should be fixed for free - they redirected me to next step, then to next one and in about 20 minutes they arranged me a home-visit by support person (the guy had to drive 2 hours to get here!). Every thing went _very_ smoothly, I am very satisfied with Panasonic's support, it was just one call with few redirections.
The service guy came in two days, unscrewed back panel, connected some kind of box to one of the boards (eeprom programmer?), turned TV onto some channel and let the box do its job for about 5 minutes - then all of a sudden spots disappeared and picture is OK now. The service guy told me that the overall picture quality should have also improved all across the screen, I guess TV sends some kind of feedback to that box for optimization.
It was free service, the service guy mentioned something about law action and that Panasonic is required to fix that for free.
Jan 09, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
My Sony television will not come on anymore. The power light will come on green, then it will start flashing red in the stand=by mode. It flashes three time then pause, then flash three more times. We were...
Check your lamp door and see if it is warped, you are getting a lamp door error. There is a switch that the door must engage for the lamp to come on.
Sep 13, 2009 | Televison & Video
LG 44SZ8D not turning on
The red light indicates the lamp is burned out. A new one is $100 to $200.
Depending on whether you use the old housing or want to order the lamp and housing together. There are lots of sources for this lamp online.
Once the lamp is replaced, it will be good as new and the lamp will last aprox. 8000 hours.
Apr 06, 2009 | LG DU-62SY20D 62" Rear Projection HDTV
TV turns on and off.
It is possible that the ballust assembly is causing the lamp to fail. You likely need to replaced the ballust with a new lamp because if the ballust is bad it has likely already damaged the lamp. If you have been handling the glass of the new lamps with your bare hands this could be the cause of the short lif as the oil from your hands will cause premature failure of the lamp.
Apr 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Will not power up
I had the same problem and It called for a lamp replacement to the tune of approx $600.00. Of course the extended warranty does not cover lamps.
Feb 02, 2008 | Zenith D60WLCD 60" Rear Projection...
Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Dec 04, 2007 | Sony KDF-E55A20 55 in. LCD Television
Red, purple and green dot
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Nov 29, 2007 | Panasonic PT-52LCX65 44" HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Akai PT46DL10 46" HDTV-Ready Television Logo
547 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
