Question about Refrigerators
Ice cubes come out of door fine but when I pour liquid on them they freeze together in one big chunk. I never had this problem with the old Kenmore that the ice tray in the freezer. Is it too cold or too hot?
  • 89 Answers
Your freezer is running a bit too cold.
the cubes are cold enough that they freeze some of the water that i pored onto them
Posted on May 26, 2009
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
ED25RFXFW01 icemaker
Sounds like the=> W10408179 Dual Water Inlet Valve
has began to seep water at the valve and out through the ice maker fill tube and down into the ice bucket. About all you can do when this happens is replace the above W10408179 Dual Water Inlet Valve. I will be here should you have questions, Thanks Sea Breeze
How to test the valve can also be found HERE
Nov 08, 2012 | Whirlpool Refrigerators
How can i solve the prob of ice cubes freezing
This may not be the problem now but by the sound of the malfunctioning unit, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The ice maker makes ice fine but when it is dumped into the ice bin it all freezes together in one big chunk. I have cleaned out the bin several times and with the same results after a day or two... Any...
it sounds like the water valve is not shutting of when it should / and flooding the tray. . . other possible cause is temp in freezer is not low enough . should be 0 to 5 deg .in tempt . ck these/ if ice cubes are too large this is a clue that valve is letting in to much water .. **** hope this helped.. I think changing the valve first would be the best ..
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Water in icemaker overflows into ice cube storage box AND CAUSES ICE CUBES TO FREESE TOGETHER AND FORM BIG ICE CHUNKS. ALSO THE FULL SHUT OFF PADEL HAS ICE FORM ON TOP OF IT
Check the ice maker after it dropped the ice cubes and when it calls for water it should be pouring it for no much more than 7 seconds ,if more it overflows, in this case the module board inside the ice maker has to be replaced(or for almost the same price with parts and labor you can replaced it for a new ice maker) But if water is sitting in the ice maker all the time , the dual valve which supplies water to the ice maker is leaking and needs to be changed (it's located at the back of the fridge in the bottom behind the cover where the water line is hooked up).
Aug 05, 2009 | Refrigerators
Ice cubes melting and then sticking together
If you have dispenser to get ice or water, there is a cover to it that opens and closes as you ask for ice. If that mechanism is not working it stays open all the time and causes your ice to melt because cold air scapes. You should be able to replace that yourself. Sears sells that part. It is not very expensive. There is a cover over the dispenser pannel. It should right behind it
If you Agur that suppose to turn the ice to dispense, that could burn up too because the agur can not turn all chunk of ice
Aug 01, 2009 | Refrigerators
In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Jun 09, 2009 | Refrigerators
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
