Question about Arrow ET200 Electric Brad Nail Gun
Brad nails not in all the way
I bought the ET200 about a year ago. It has not been used a lot. It doesn't matter what size brad I use I always have to sink the 1/4 inch with a hammer. Is this Common? Can this be adjusted?
  • 26 Answers
Mine wont sink them into corrugated cardboard, two sheets.
Posted on Jul 11, 2015
  • 4 Answers
There are no adjustments on any electric stapler / brad nailer that I've heard of , only the pnumatics. The electric staplers/brad nailers only work well in softer woods
Posted on May 27, 2009
ARROW BRAD NAILER ET200 jambs all the time. can it be adjusted out or repaired to work?
Arrow Fastener Nail Master ET200 - YouTube
? 0:42
www.youtube.com/watch?v=-Y8OBdU29Qc
May 30, 2012 - Uploaded by Piranhamonkey
I made this video to show how a new, out of the box Arrow NailMaste... ... However, my NEW nail gun, jams up a lot, meaning I have to take the ...
Sep 12, 2015 | Arrow ET200 Electric Brad Nail Gun
Where to find non-marring bumper for arrow et 200 nail brad gun part number 2815
The non-marring bumper for the ET200 nail gun is Part #2815. Send a note together with a check for $1.50 plus $1.00 S&H to Parts/Service Dept., Arrow Fastener Co., 271 Mayhill St., Saddle Brook, NJ 07663.
Mar 26, 2013 | Arrow Heavy Duty Nail Master Electric Brad...
ET200 won't shoot nails. The light works but it doesn't shoot. The chamber is clear of jammed nails HELP!
I had this problem too, and finally figured out what was wrong. If you have cleared a jam and have put the nail gun back together, then all you get is a 'thunk' when you try to drive a brad, you have put it back together wrong, as I did. Take the two screws out and pull out all four pieces -- three plates and one skinny 'T' shaped piece. Look inside the unit and you'll see a pointed piece, which is the hammer that drives the brad in. This next step is key: put the first plate back in (the one that is flat on both sides) making sure that it slides in UNDER the hammer. The hammer fits loosely in its housing, so it may help to turn the nailer upside down so that the hammer falls down, giving you the room you need to get the plate in--again, so that it's UNDER the hammer when you turn the nailer back over. Once you have done this part, simply slide the second piece in (the one with the fluted strip down the middle), slide it in fluted side up, then the 'T' piece (with the 'T' in first) then the last piece with the wider groove that contains the 'T' piece. Replace screws and you're back in business! This information may be in the instructions, but I have long ago thrown those away.
Oct 26, 2012 | Arrow ET200 Electric Brad Nail Gun
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
Brad nail only goes 1/2" into wood. there is no
You might get better penetration if you use your other hand to press the gun down firmly onto the surface before you pull the trigger. (This will help if the gun tends to jump a little when you fire it.) Or, if the surface you are firing into might not be rigid enough (like a thin board that is not supported) - in that case you might improve the penetration by better supporting the surface you are nailing into, perhaps by placing it on the floor. On the other hand, this may simply be a case that the gun is not powerful enough to do what you want it to do. To test that theory, try it into a piece of soft wood (like a 2X4) or find a soft thick material as a first layer over the wood you are using. Perhaps you can use shorter nails - thin brads in wood don't gain much strength beyond 1/2 inch penetration anyway. The length of the brad only needs to be about 1/2 inch longer than the thickness of the first layer of material. I hope this helps, good luck Al K
Feb 24, 2011 | Arrow ET200 Electric Brad Nail Gun
A 1 1/4" brad nail only penetrates 1/2 inch
Hi, There should be a power adjustment on the top of the driving head. Make adjustments there, and the penetration should improve.
--W/D--
Will a 1-1/4 inch nail fit in the ET-100?
Unless you mean ET200 I would say no. The 200 will take an 1-1/4" brad nail.
Jun 27, 2010 | Arrow No. ET100 Electric Heavy Duty Nail...
Does the ET200 nail the 1.25 Brad all the way, the gun that I just purchaesd goes in only half way leaving .75 inch out of the wood
Sorry no answer for solving, But my ET200 does the same as you are describing. What's the purpose of using this tool if I have to go back and set each nail if the ET200 is suppose to do it for me? I will check back, but if you have found the solution, I would like to hear it. bwthompso@gmail.com
Oct 25, 2009 | Arrow ET200 Electric Brad Nail Gun
I just bought a new ET 2000 , loaded it with 32mm nails, I tried it and the nails stick out. How do I select the right size in the nail gun? Sandy
Lowes close by you?
Take your gun to the tools section and ask the man or woman that works there what kind of fasteners you can use.
or
visit www.arrowfastener.com and search your machine.
It should have told you in the box what to use ...oh yea, you tossed those instructions.
I hope this helps you
a
Oct 12, 2009 | Arrow ET200 Electric Brad Nail Gun
Wher can I purchase a replacement circut board for an Arrow ET200 Eletric Nail Gun. What I have is an ET200 - 110v Rev.2 I would like to purchase on line.
Do you still need this? I have a good board from my ET200. I dropped it, and the piece that keeps the nail driver steady when it shoots in & out broke off. However, the gun still functions fine. Let me know.
Oct 09, 2009 | Arrow ET200 Electric Brad Nail Gun
Arrow ET200 Electric Brad Nail Gun Logo
854 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
