Question about Jenn-Air JJW9530C Expressions Collection Electric Single Oven
Displays function not available when trying to bake/broil/clean
Whenever i press the convect/bake/broil/clean or options button it says that function not available and its not allowing me to use the oven, in the top right corner b the timer2 button it displays 1c2c the only thing i tried was trying to reset the power When I press the bake, convection or briol it displays the same message "function not available press help" and it says 1c2c beside the time display. We are going to try reseting the breaker and unplugging the whole oven to see if that fixes it.
catriver
  • 878 Answers
SOURCE: Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Posted on Apr 10, 2007
SOURCE: The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
Posted on Dec 30, 2008
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
MNfisherman
  • 11896 Answers
SOURCE: Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Posted on Aug 25, 2009
ginko
  • 19396 Answers
SOURCE: I have a Jenn Air
Follow procedure below to enter the Test Mode and reset.
1. Press
SETUP pad.
2. Press
DOWN ARROW pad three times until SERVICE is displayed.
3. Press
SERVICE pad.
4. Press and hold
BACK and ENTER pads for 5 seconds.
5. Press
SERVICE pad.
If that does not work, disconnect power again, this time for longer, let say one hour, then perform procedure again.
Here parts
Replacement parts for JENN-AIR JMW8527DAW
Here tech sheet
http://www.servicematters.com/maytag...s/16022823.pdf
And manual
http://www.servicematters.com/maytag...s/16022821.pdf
Posted on Aug 25, 2010
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
I self-cleaned the convection oven on my sc302tw, and now it does not heat on any settings, convection, bake or broil. It is 14 years old.
Looks like the sensor has tripped... on my Bosch oven, I opened the back. Connected to the thermostat is a switch with a little button which pops out to prevent the oven from overheating... push in the button to reset it and it should work
Nov 06, 2013 | Thermador Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
How do i turn on the bake option on the self cleaning oven?
to just turn on the bake option there should be a bake button to press as well as a self clean option and broil cycle.
Jun 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven won't heat after self cleaning
There is a overload thermostat located on the rear of your oven that needs to be replaced.
Self cleaning operations are not recommended by this technician.
Mar 02, 2009 | Whirlpool Ovens
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Jenn-Air JJW9530C Expressions Collection Electric Single Oven Logo
138 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
