Question about GE Monogram® ZMC1095BFBB / ZMC1095WFWW Electric Single Oven
Convection works but Microwave does not heat
I have a GE Monogram Convection Oven / Microwave wall unit (Model ZMC1095). The convection continues to work great however the microwave does not heat. Starts out fine, then makes a strange sound, then returns to a normal process noise for the rest of the time. Food, however, comes out ice cold. Any suggestions? microwave will turn on, but will not heat
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
Posted on Sep 30, 2010
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
HOw to replace light bulb microwave KEMS308
Unit has to be removed from wall top panels removed to replace if can live with out it great bulb is cheap labor 100-150
Jan 24, 2014 | KitchenAid Architect II KEMS308S 30"...
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
Nov 04, 2009 | Jenn-Air Ovens
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Microwave stopped heating
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Dec 01, 2007 | GE Monogram® ZMC1095BFBB /...
GE Monogram® ZMC1095BFBB / ZMC1095WFWW Electric Single Oven Logo
698 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
