Question about Amana SXD524VW Side by Side Refrigerator
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Freezer won't stay cold and won't go below 10 mostly at 20. The fridge fluctuates between 40 and 60 degrees. Not sure what the problem is. Amana side by side. Not sure the model.
  • 420 Answers
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
Posted on May 26, 2009
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Kenmore 596.69142992 bottom freezer temp fluctuating from 10 to 40 degrees. Refrigerator maintains steady 40 degrees. No ice on coils.
The freezer temps fluctuate that much, I am thinking your cold control is going bad... Kenmore Refrigerator Temperature Control Thermostat W10752646
You can clean the fridge with warm soapy water and/or a hand steamer
Jun 29, 2016 | Kenmore Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Hi,Ihave had my electrolux fridge freezer for two years now and it is sited in my garage.When it gets really cold the freezer turns off defrosting everything,just found out if it drops below 10 degrees it...
Good day,
Not really. Domestic refrigerators are designed to operate in an environment where people live.
Most all manufacturers recommend that they not be placed in an area that goes below 55 degrees.
At any temperature below that it starts to degrade.
Cold enough and it will not work at all.
The reason is once the fresh food compartment reaches it's normal temperature of 33-37 degrees, it shuts the whole machine off.
That is by design, on any refrigerator like yours that has only one compressor and cooling fan motor.
As well, there are other issues. In that situation, the machine could well stay off 12 to even 24 hours.
The compressor has an oil sump in it, and the oil becomes very thick. When it finally tries to start, it creates a very stressful situation for the compressor, and could substantialy reduce it's life.
Jan 17, 2010 | Freezers
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
635 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
