Question about Samsung SMH7174BC Microwave Oven
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
  • 2 more comments
  • sherlinc Nov 21, 2007
    Our Samsung microwave is displaying error code E5 after we were using the stove to heat up some food. The microwave is an "above oven" microwave and has worked fine for a year. Not sure what to do...
  • NC141 Feb 06, 2008
    Received E-63 code when popping pop corn. Used the popcorn button. Some of the Popcorn was burned by the time the oven cut off. Turntable was very hot.
    Let oven cool off and heated a cup of water for 1 minute. Haven't tried another bag of popcorn yet.
  • Anonymous Feb 27, 2008
    Same OTR microwave only in white.  Same problem when I popped some popcorn.  A few kernals burned a little.  Just hit the cancel and boiled 2 cups of water to test it and it worked fine.  No clue.  Maybe the E63 indicated burnt food?
  • badger998 Jul 18, 2008
    Had the E-63 message while making popcorn immediately after burning some popcorn. Samsung's manula and website were useless. Also boiled water without a problem, but have not tried another bag of popcorn yet.
  • 473 Answers
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Posted on Oct 21, 2007
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: error code E 63
I'm not finding that error code.
Does it come on 2 minutes after you plug it in?
If so, it may be a failing keypad or door switch / mount.
Of two minutes after you have been cooking?
That may indicate a bad humidity or other sensor.
Please give more detials so we can help further.
Posted on Oct 22, 2007
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Jun 14, 2012 | Samsung SMH8165W Microwave Oven
My microwave says E-63. What does that mean?
E63 is a "T1 Max Time error".
It may mean you have a bad PCB assembly, but I would suggest a hard reset.
Unplug it from the wall outlet for a minute, then plug it back in and try again.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 26, 2010 | Samsung SMH7174BC Microwave Oven
Model # MMV5165BAW Error code - E-63
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Here's the explanation of that code:
E-63 T1 Max Time error. PCB assembly.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Dec 19, 2008 | Maytag Microwave Ovens
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Jan 04, 2008 | Samsung SMH7178STD Microwave Oven
Oct 21, 2007 | Microwave Ovens
Re:tv
Hi Redd, You might have better luck posting this under Sharp TVs: http://www.fixya.com/support/sharp/standard_televisions The black lines at the top of the screen are usually an indication of a problem with the vertical output section. It's often bad electrolytic capacitors, the vertical IC, or both. That's apparently not a US model, so it will be hard to find the values but you could contact Sharp Philippines: SHARP (PHILS.) CORPORATION [Philippines] Km.23 West Service Road, South Superhighway, Alabang, Muntinlupa,Metro Manila, Philippines Tel: 63-2-842-1371 Fax: 63-2-842-0530 Service Center Tel: 63-2-807-4991/4992 Fax: 63-2-807-0388 Home Page: http://www.sharp.ph/ Good luck.
Dec 19, 2006 | Sharp R-930AK Convection/Microwave Oven
Microwave Ovens Logo
1,276 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
