Question about Lexmark JetPrinter Z11 InkJet Color Printer
Can't print in color
Lexmark Z11 will only print in Black/brown, can't get it to print any colors.
  • Lexmark Master
  • 684 Answers
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Posted on May 27, 2009
I need to get instructions on how to properly line up the print heads after installing a new cartridge on my printer, a Lexmark Z11 color printer. Thanks.
In XP - Maybe in Vista and 7 too.
Start
Control Panel
Printer and Fax
Highlight your printer (Z11)
RIGHT click it
Select Properties
Print test page
Follow directions
Dec 22, 2009 | Lexmark JetPrinter Z11 InkJet Color...
My lexmark z11 prints everything 3 times. how can i stop this from happening?
if your printing in word click on print setup that should pull up a dialog box where it says copies put zero and save it. You should be good to go from there.
Sep 23, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Z11 won't work
Remove the software for the printer through ad remove programs in control panel
Then keep unit unplugged from usb. Install the device drivers then plug unit in when software asks or after it requests a reboot.
Jan 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
PRINTER INSTALL
plz download the drivers from the lexmark website
Jun 16, 2008 | Lexmark JetPrinter Z11 InkJet Color...
New cartridge 70 black will not print
buy some new one..... i think thats old one hahahaha joking ....fix the cartrige
Mar 01, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Reinstall printer
You can download your driver here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z11+Color+Jetprinter
If you have Vista:
Please note: At this time, Lexmark does not have a driver for this printer which is supported by Windows Vista.
However, people have reported success using the Windows 2000 driver on Vista.
Feb 11, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Black cartridges won't print. Color cartridge works.
Why dont you go to the store that you bought the printer from and ask one of there people there fix the problem..
Dec 28, 2007 | Compaq Inkjet Ij300 Printer
Lexmark z11
Your printer thinks you are using a color cartridge. If have the lexmark printer manager software, go to "install new cartirdge" and tell it that you are using a black cartridge. Otherwise, install a printer driver, reinstall the printer, and set it up again.
Driver link (if needed):
Dec 24, 2007 | Lexmark JetPrinter Z11 InkJet Color...
Open Questions:
I have a Lexmark Z11 that sat unopened in the box for several years until it was given to me as an emergency printer. The black ink cartridge had been pilfered by the original owner ( he got several of the se printers on clearance for $15 each). I bought a remanufactures high capacity cartridge. It workef fine for the three days of printing I did last week (about 25-30 pages of resumes and reference letters). When I went to use it a week later, it goes through the motions of printing but no ink is put on the page. I ran the clean cartridge several times but still no ink. I tried the new still-in-the-box color cartridge and did get color on the page in the alignment trial, but it was faded and full of white lines. I figured the cartridge was just old. It could be the ink leaked out of the remanufactured cartridge, but when I gently blew on the air hole I got a small splat of ink. (I used to be a sales rep for Canon printers a dozen years ago and we were told to do that to see if the cartridge still had ink.) I deleted and reinstalled the printer, unplugged and replugged cable and power cord twice. The printer receives the command and goes through the motion of printing, but as I said, no ink is put on the page. I have come to the conclusion the perhaps the remanufactured cartridge is at fault and I should take it back for an exchange, Can I get your take on it - is it the cartridge or the printer? Thanks! -Kathleen Brockway
Mar 01, 2017 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark JetPrinter Z11 InkJet Color Printer Logo
272 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
