Question about HP PSC 1210 All-In-One InkJet Printer
Repeated paper jams with envelopes I can't seem to even get one done out of the printer.
  • guate6 May 26, 2009
    Thanks for your help. This office jet doesn't really heat up (not like a laser printer). What I ended up doing was folding the envelope edges slightly from both sides, so it could go through the rollers easier and not be so rigid. I also had to increase the indention of the document because it seems it starts to print before the envelope even gets there.
    There's no stuck paper and the rollers are good. Thanks again.
As a previous suggestion said, the problem seems to be the rigidity of ther envelope, my most successful solution has been to orient the envelope so that the seed direction is the short dimension and to feed the envelope with the fold over top first. Also giving thge envelope a slight bend in the right direction helps.
Posted on Jun 18, 2009
  • 564 Answers
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 26, 2009
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
Paper jam on a dell 924 cannot see the envelope that is stuck
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker /or even envelope with adhesive printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
May 18, 2011 | Dell 924 All-in-One InkJet Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Paper Jam inside the printer Lexmark 5470
Firstable, you need to remove these pieces of paper from your printer. It is possible just removing a part of the printer located in the back or the bottom of it. Then you need to know that if you want to print on an envelop, it's necessary to format the printing settings. Just go to printing format and choose envelop
and also the dimensions of the envelop you want to print, then after this it'll be simple.
Dec 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
False paper jam
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Printer jams
Page 11 of the manual does not list envelopes. It was not designed for printing envelopes.
Jan 10, 2008 | Lexmark X75 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
108 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
