Here's a link for the owners manual for the 300 model. Click on it and it will open as a PDF document that you can print.
http://www.rascalscooters.com/manuals/300_manual.pdf
The ammeter back in the trunk should be registering when you plug the scooter in. If it isn't, this doesn't mean that it isn't charging as the meter itself may be bad. Put it on charge for a few hours and see if the "fuel guage" on the top of the tiller comes up to full. If it does, than your charger is okay and you just need to ignore the ammeter not working until it doesn't charge at all anymore, then the charger is bad. Note too, that later on when the batteries get weak and you can only go a little ways, that it still means your charger is okay, batteries not. Even bad batteries well show a full charge, but they won't take you far at all. If the batteries don't show a full charge after a few hours, then you need to replace the onboard charger.
Good luck
