Question about Liquid Video A170E101 Monitor
Power adapter on a L17LCD2
IS IT JUST LIKE A TUBE MONITOR POWER CORD OR DO IT HAVE TO HAVE POWER ADAPTER TO A AC CORD.
    Novelist:
  • 137 Answers
It uses an adapter in-line, so it won't work with a basic AC cord. It uses a 19v 3.5amp adapter which may be difficult to find, but I think the specs are that it has a 3mm inside diameter and a 6.5mm outside diameter for a straight barrel style plug end that is 9.0mm long.
maybe you can find something that will work or build one from RadioShack parts. Don't take my word on anything though. I'm incompetent and lie.
Posted on Nov 05, 2007
I need power cord and AC adapter for an Acer H236HL BID monitor
You may want to call Acer support for them to send you a new power cord and ac adapter. Acer technical support number is 1-800-816-2237
May 15, 2014 | Acer Office Equipment & Supplies
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
Driver download
Most Liquid video tv's and indeed most TV's these days use a RCA power cord. They are available cheaply online and in some dollar stores. You may already have one you can use to test the tv with as desktops use them and some laptops use them as well.
Jul 17, 2013 | Liquid Video L17LCD2 17" Flat Panel LCD...
Damaged power cord
The power supply AC adapter power cord is the same as used for PC power cord, local PC repair shop should have them.
Or you are looking for the AC adapter is 12v 4A power adapter, try Ebay
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | SVA-USA 9005B (Black) Monitor
Need a power cord
Most monitors take the same power cord as a desktop power supply or printer. They are available at most stores with computer gear. The monitor spot where you plug in the cord will be a irregular hexagon forming a regular rectangle on one half and three sides on the other. The monitor will have three prongs. The wall outlet plug is a standard grounded plug.
For a picture of the cable ends: http://www.superwarehouse.com/Cables_to_Go_6_FT_Universal_Power_Cord/03130/p/14181
I hope this helps.
Apr 12, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
Where do I get lost cords for this monitor?
are you mention about the AC adapter or just power cords. For pwer cords is everywhere, but ac adapter you have to know the specification for the power input/output and size of plug since I can't tell the model on your description.
Mar 22, 2010 | Samsung SyncMaster 245BW Monitor
My monitor keeps going on and off. It will be off
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output/inverter board and you maybe able to get service, parts and DIY info from
www.lcdparts.net
Dec 13, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
Liquid Video A170E101 Monitor Logo
193 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
