Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch washing machine leaks at right bottom
My model WFMC3301UC washer leaks about a cup of water with every load. Water comes out near the round "cut out" on the bottom, right. I opened up the round "cut-out", I see something round, black, that I turned and opened; water gushed out.
I've read about gunk in a pump, where is the pump on this machine?
Thanks!
  • Bosch Master
  • 3,463 Answers
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
Posted on May 26, 2009
  • rex496 Jul 06, 2011
    I've have a Bosch washing machine that has leaked since new. While under guarantee a technician assured me it was because the water was very "soft" in Vancouver and only a small amount of soap should be used. I have been using very little soap and the problem has persisted - for about 9 years. I'm just very irritated by it - and have never understood the explanation. There is never any foam generated. I'm now about to rent my house out and can't expect my tenants to put up with this - and am contemplating buying another (NON BOSCH) machine. I feel that I paid for more than I got - and seldom use the machine. The experience has not been a pleasant one.
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Maytag MHWE201YW Laundry : Front Load...
Bosch WFMC3301UC washer. The water will not flow into the machine. After a few minutes we see an error msg E02. I had replaced the hot water inlet valve two months ago because it developed a leak. No...
Bosch WFMC3301UC washer. The water will not flow into the machine. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 12, 2011 | Bosch WFMC 3200 Front Load Washer
The water leaks from the back side of the washer just under the cold water hose (at the top of the washer). Their is a round plastic part with some open space in the part. When the washer goes to rinse...
that is the drum vent. there is a mushroom valve inside to prevent water from coming out.when it fails, water comes out of vent. the valve either needs to be replaced or cleaned and reinserted. the top cover will need to be removed to do this. remove 2 back bottom screws and slide top towards rear to remove.
May 10, 2011 | LG WM-2277HW Front Load Washer
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold...
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Jul 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Mar 16, 2008 | GE WSXH208A Front Load Washer
Flooding
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Jun 17, 2006 | Whirlpool LTE5243D Top Load Stacked...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
2,085 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
